SB1450 Advice, Please
Old Jun 6, 2019 | 06:17 PM
FatBob2018's Avatar
FatBob2018
Originally Posted by P51Driver
This may or may not be relivent to this discussion. I just recently found that when checking the oil level on my 2018 M8 Softail if I let the bike when hot idle two minutes on the jiffy stand for two minutes then shut it down and wait a couple minutes and check the oil level. The oil level reads three dots low on the dipstick. Now if I let it idle upright for two minutes then put it on the jiffy stand. The oil level reads three dots higher on the dip stick over the previous reading. It seems that letting idle while upright let's the oil get sucked out of the sump. I know that HD states that idling on the jiffystand for two minutes is the reçommended procedure but it would appear this will cause the oil level to read low.
Yes, and this is another potential cause of sumping/overfilling. If you shut the bike off right away without letting it have any chance to idle down (upright), then it won't have a chance to clear the accumulated oil out. So if you shut it down right away, then measure the oil, it's going to read low, which will lead some folks to overfilling it.
brettnbama
Jan 10, 2013 05:40 AM
trigg
Oil Archive (no new posts)
Jun 13, 2012 04:47 PM
nealhix
Sep 18, 2011 08:48 PM
sportster77
Ironhead
28
May 28, 2009 08:30 PM
Nick
Aug 1, 2007 03:46 PM
