Cold start
Old Jun 12, 2019 | 08:13 AM
05cvoeg's Avatar
05cvoeg
Default Cold start
Having a problem in the morning with brief hesitation only when cold. Bikes a 18 limited with stage 2. Had at the dealership they couldn't find any thing replaced the plugs but didn't help
Old Jun 12, 2019 | 09:45 AM
hypecat's Avatar
hypecat
My 2017 does the same thing, seems like the battery is the issue, the dealer checked that and said it wasn't. When this has happened to me in previous bikes, that battery completely died a while later (maybe 6 months).
Old Jun 12, 2019 | 10:24 AM
mjwebb's Avatar
mjwebb
I was going to suggest that but seemed like prematurely going bad..we're approaching 3 years on our originals and they have always fired right up, but I keep them on tenders at all times..should get 4-5 years out of them that way
Old Jun 12, 2019 | 10:48 AM
hypecat's Avatar
hypecat
I bought my 2017 in September of 17, I think the battery wasn't maintained for quite a while.... I should have asked for a new battery when I took delivery.
Old Jun 12, 2019 | 10:49 AM
KrustyKush's Avatar
KrustyKush
If the OP is referring to a hesitation in motor turning over while trying to start the cold motor, then it is certainly the battery. The battery is probably half discharged.
Short trips, hot weather, several motor starts each day equals gradually discharging battery. The first sign of it is that momentary hesitation when you push the start button.
If the OP is regularly using a charger or tender while the bike is sitting still, then maybe he's got a defective charger.
Old Jun 12, 2019 | 11:53 AM
05cvoeg's Avatar
05cvoeg
It starts fine cranks right up. I have 3 corners to get to the main road it hesitates while getting up to spend from the turns
Old Jun 12, 2019 | 11:58 AM
mjwebb's Avatar
mjwebb
ok, let's start from the beginning "Bikes a 18 limited with stage 2."..is this bike new, new to you or you've had it since new and have xxx amount of miles and this is behavior is a recent development, or has always done this, or since the Stage 2, or..some more history of the bike and how it's performed leading up to this might help some of us 'speculate better'..LOL
as often is the case, WTMI is better than not enough
Old Jun 12, 2019 | 12:08 PM
05cvoeg's Avatar
05cvoeg
I got the bike new later in the fall. Had stage 2 put in over the winter. Run great so far just started acting up recently.
Old Jun 12, 2019 | 12:34 PM
hypecat's Avatar
hypecat
I thought you meant it hesitated to crank when cold... You have a different issue, I'd have the dealer check the tune.
Old Jun 12, 2019 | 12:51 PM
DTTJGlide's Avatar
DTTJGlide
Well it shouldn't be doing it,but we're not going to be able to fix it over the internet, so that means a trip to the dealer. Till then the easiest fix is probably to let it warm up for a minute or two before you take off.
CaffeineBuzz
Jul 13, 2019 10:16 AM
stbob07
Oct 31, 2013 06:31 PM
BiggDogg
Mar 21, 2012 08:23 AM
mikel61101
Jan 23, 2010 12:40 PM
eddie0324
Jul 2, 2006 01:00 PM
