Clutch pull is excessive
Old Sep 29, 2019 | 04:12 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by $tonecold
You get the same effect from the AIM actuator. It is not going to move the clutch as much as the stock actuator.
Not sure what you mean by actuator. If it's the clutch slave, then yes it lowers clutch lift. You still have full lever travel and the pull is lighter. Reduced reach lever does not lessen the pull. Friction zone probably moves in a little..
Old Sep 29, 2019 | 04:23 PM
$tonecold's Avatar
$tonecold
Actuator is how Harley refers to the slave cylinder. I think you are correct on all points.
Old Sep 29, 2019 | 04:37 PM
Max Headflow
I didn't know that. Thanks.
Old Sep 29, 2019 | 07:10 PM
YPD485's Avatar
YPD485
Originally Posted by NorthWestern
I bought the Muller, and am installing it soon, and will give feedback.
Mine is excessive, as well. I was hoping it would get better, but after 2K, I have had enough. My buddy's '18 RG is like butter compared to mine.
I've gone through 3 of the AIM units and have given up on their slave cylinder working like they advertise. Waste of $250.00.
Let us know how the Mueller slave cylinder works out. So far, the few who have installed their unit seem to love it. But I don't think anyone has many miles (over 5K) on it yet.
Old Sep 29, 2019 | 07:34 PM
Hoginedgewood's Avatar
Hoginedgewood
I don't think it's politically correct to use the word s____ any more
Old Sep 29, 2019 | 08:40 PM
dawg's Avatar
dawg
I’m up to 7500 on my Muller and all is still great.
Old Sep 29, 2019 | 08:59 PM
$tonecold's Avatar
$tonecold
Well if you think that is bad, I guess it really sucks that the unit on the other end is commonly referred to as the “Master” cylinder!
Old Sep 29, 2019 | 09:46 PM
Max Headflow
So there are leftist progressives here? Bummer.
Old Sep 30, 2019 | 05:38 AM
Hoginedgewood
I don't have a problem with it.
Old Sep 30, 2019 | 05:40 AM
Hoginedgewood
The reduced reach lever simply moves the lever closer to the handlebar so that it's easier to get more hand on it. It does nothing as far as reducing lever pull but simply allows for better grip. Side effect is that the pressure plate moves less since the lever has less travel.
That's the exact point I was thinking. With less movement in a clutch basket that barely has enough travel it seems like a recipe for problems.
