Sumping? Questiom
Old Sep 30, 2019 | 06:53 PM
MTBIG G's Avatar
MTBIG G
Originally Posted by TracerBullet
Stupid question but when this happens, does the bike restart?
Fair question. Short answer is yes
Old Sep 30, 2019 | 07:16 PM
Keithhu's Avatar
Keithhu
Originally Posted by Dynamick
Ask the guy on the forum who had three stock 107's sump on him
That would be me.
Originally Posted by KrustyKush
"Sumping" has been associated with a variety of engine failures. Looking through sumping-related threads reveals this very clearly. It isn't just some amorphous nobody-knows-why characteristic of poor engineering and design. Almost all instances of sumping are related to a component failure inside the engine. A failed oil pump. A defective case (hole in it). A failed balance gear. A blocked oil or breather passage. Etc.
I believe this is why most of the sumping cases are related to "upgrades" done on otherwise perfectly fine engines, and done poorly. One guy here recently called for a class action suit against Harley because of this and other problems, and then a few weeks later revealed that his sumping was cause by a screwed-up "upgrade."
Some engines have sumped even though there had been no "upgrading" on them. These are rare, extremely rare. And probably result from faulty assembly at the factory. Sometimes things leave the factory defective. But it is extremely rare.
I must be something of a miracle then. Also, I dont think I agree with your assessment that its always a failure. I dont think we've seen oil pump "failures", other than various versions of it not being up to the job, but they don't malfunction per se.
Originally Posted by Keithhu
Had 3 stock 107's replaced under warranty.
Yep.
Old Sep 30, 2019 | 07:21 PM
TwiZted Biker's Avatar
TwiZted Biker
Yeah, still trying to get my head around the odds of that and I can't win so much as a $2 lottery ticket...
Old Sep 30, 2019 | 08:40 PM
bradsULtd's Avatar
bradsULtd
Originally Posted by 19FLHX
Has anyone with a stock 107 had a sumping issue or is it just with higher stage upgrades? or the 114's?
Where ya been hiding? Have your questions been answered? Do you have any more?
Old Sep 30, 2019 | 08:54 PM
triumph900's Avatar
triumph900
I’m one of the “lucky” few I guess. 2018 100% stock 114 started sumping at ~1500 miles.
Old Sep 30, 2019 | 08:57 PM
dkschroyer's Avatar
dkschroyer
Just found today that my 2018 street glide, that is stock except slip-ons, has sumped. Took it to the dealer who is going to do the vent repair. Hope this repair works. Any input on anything I should request from the dealer, or watch out for would be appreciated.
Old Sep 30, 2019 | 09:06 PM
Keithhu's Avatar
Keithhu
I doubt it will because the vent addresses the transmission fluid tranfer to the primary, not sumping.
Old Oct 1, 2019 | 05:18 AM
dkschroyer's Avatar
dkschroyer
Thanks Keith. You are correct that I confused the two issues.
Old Oct 1, 2019 | 05:49 AM
sandrooney's Avatar
sandrooney
I am sorry for you guys that are having issues but my 18 Heritage 114 is awesome. 9200 miles and seems to run better every time I ride it.
Old Oct 1, 2019 | 10:32 AM
KrustyKush's Avatar
KrustyKush
Due respect to your own experience, which I think all agree is wildly rare, and inexplicable, except that these wildly rare things do happen in real life.
As far as what failures caused engines to sump and die, very little is known down here in the provinces. One or two here at HDF has reported being present when a sumped motor was "partially" torn down at the dealer before it was crated and shipped back to the factory for analysis. I am certain the engineering folk at the factory are aware of exactly what issue caused each and every sump situation, because they are experts who carefully tore down those engines and did a scientific, measured analysis. But we at HDF are not in the feedback loop, so we don't get reports about what the engineers found in those broken motors.
However we do know a few things. I've been following this in HDF for two years, and there is quite a lot of user level information posted here. Riders have had engines sump due to component failures. One example, the guy who posted pics of a hole in a case in the cam chest. Another posted pics of a balance gear that disintegrated and lodged a tooth in the oil pump. Another with a breather passage blocked due to a botched "upgrade." Most, however, seem to have no idea what caused the sumping failure. The motor was removed and replaced, the dead one shipped back to the factory.
A careful analysis would require complete disassembly of the engine. Measurements done by qualified experts. A rider standing by while heads and cylinders are removed, and peering down into the holes, does not constitute careful engineering alalysis. So rider saying he witnessed the "tear down" of the motor and observed no particular failure doesn't prove anything whatever. Moreover, I seriously doubt that the average Harley dealer shop has the kind of technical expertise to perform such analysis.
