Sumping? Questiom
Old Oct 3, 2019 | 05:52 PM
  #31
Heatwave's Avatar
Heatwave
Member
Originally Posted by hellonewman
But before anything was obsolete it did the job as intended. A rotary phone is obsolete now no? In this case the pump was obsolete before it was even put in the engine so that said maybe its obsolete but not by your definition.
The facts would suggest the “obsolete” M8 oil pumps did NOT “do the job as intended”. Otherwise HD would have never had to issue 10 revised versions of SB1450 or the dozen or so redesigned M8 oil pumps they have released every couple of months to address sumping.
Old Oct 3, 2019 | 07:23 PM
  #32
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Old Oct 3, 2019 | 07:32 PM
  #33
Wizardofaus's Avatar
Wizardofaus
Originally Posted by Keithhu
I doubt it will because the vent addresses the transmission fluid tranfer to the primary, not sumping.
The problem’s been around since 2017, Harley’s just released the 2020’s.
Now I’m not saying the problem‘s still there, But I wouldn’t buy one with your money.
Wiz 🤣
Old Oct 3, 2019 | 07:54 PM
  #34
Wizardofaus
Originally Posted by VDeuce
HD is never going to admit to anything. The only evidence from them comes in the forum of multiple pump redesigns, which we all know wouldn't be happening if there wasn't a problem.
Anymore, sumping has gotten to be like a conspiracy theory.
Either it happens to you and you know it, or it doesn't happen at all.
Let’s not forget Harley’s going to fix this so called problem as cheap as possible so swapping out a pump is about as cheap as they can do it.
3 years down the road the best fix thats been offered is an oil pump, a rubber hose vent pipe, And I’ll swap out ya 1500 mile engine cos we don’t know what the hells going on but we’ll keep ya money, tie up ya bike in service till we get approved from the mothership for repairs.
The M8 just ain’t worth the price of 30,000 of Advil.
Wiz 😟
Old Oct 4, 2019 | 05:31 AM
  #35
NorthWestern's Avatar
NorthWestern
Wiz 🤣
What does this proclamation have to do with what he said? He was pointing out the difference in 2 issues, and you stop by to drop that nugget?
Old Oct 4, 2019 | 05:43 AM
  #36
dajogejr's Avatar
dajogejr
In reading the SB, it states a cause is extended high rpm or heavy loaded.
Exactly what rpm and how long.
My furthest trip is 250 miles one way, one stop...80 to 85mph and I'm 280ish geared down.
This type of riding was enough to make it transfer, which was fixed at 1500 miles with the vent tube.
Over 7K now, not an issue.
What is the magical load and rpm HD is stating could cause sumping?
My bike lives at 2500 to 3500 rpm unless I'm idling through my streets or passing/getting up to cruising speed.
Keith, what rpms or loads caused yours to sump?
Old Oct 4, 2019 | 06:38 AM
  #37
Keithhu's Avatar
Keithhu
Just highway speeds. But the first time it happened, it was after I returned from Sturgis. On that trip, to and from, I was riding at 90 mph on I 90 for hours, no issue. Engine just purred, and I was thrilled. Had 5600 miles on it, then when I was riding on the highway in September in Michigan, about 80 mph, it happened.
But at no time (all 3 times) was I at what I would consider high RPMs for an extended period. 90 mph is only about 3300 RPMs if I recall correctly.
I never got more than 600 miles on the replacement engines. Last time it happened, they replaced the bike, from a 17 to an 18, but I just traded the 18 in for a 2020 Road Glide Limited and I freakin love it. 582 trouble free miles so far!
(I rode the 18 to and from Sturgis as well, no issues. Had about 9400 miles on it when I traded it in for the 2020)
Old Oct 4, 2019 | 08:38 AM
  #38
BrandonSmith
I just want to clarify: you were reading the sumping service bulletin and it states that high load and/or high rpm can cause sumping, but you don’t see sumping at high loads and/or high rpm? The only thing you have seen at high load and/or high rpm is the unrelated issue of primary-transmission transfer? Consider yourself lucky! Lol
My bike also lives at 2500-3500 rpm and it has not exhibited any symptoms of sumping, but remember there’s two types of M8s - those that have sumped, and those that don’t know if they’ve sumped.
Old Oct 4, 2019 | 08:56 AM
  #39
dajogejr's Avatar
dajogejr
You are correct.
Regarding transfer, if I putt around town, 55 and below, no extended time on the throttle...it wouldn't move a drop.
When I took it to work, 1 way is 26 miles and 90% freeway at 80+, it transferred.
I would think these are the same conditions that would apply to sumping.
But you are spot on B, I have not yet experienced it.
No loss of power, no burn smell, no engine braking feel...
Keith, got it...let's hope the bad luck is behind you.
Old Oct 4, 2019 | 11:14 AM
  #40
Wizardofaus
My point is ,
Buy one if your confident enough you won’t have a problem with a 25+ bike sumping,
Don’t if ya so ..... That’s all.
Wiz 🍻
dceggert
Milwaukee Eight (M8)
22
Apr 1, 2019 11:22 AM
Sagostino
Jul 26, 2014 02:49 AM
Tltrump
Exhaust System Topics
Nov 28, 2007 01:26 PM
intruder400ex
Oct 25, 2005 11:02 AM
