Oil Pressure Light - and then, not
Old Oct 6, 2019 | 01:23 AM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Originally Posted by SomeOld Biker
My 17 RK will get the oil light to stay on if I start it up too quickly. But if I wait a few seconds after I turn on the ignition then hit the start button no oil light.
Logically that makes no sense, since nothing other than the fuel pump is affected by what you’re describing. I wonder why your oil light comes on.
Old Oct 6, 2019 | 08:21 AM
TexasScott's Avatar
TexasScott
The only thing that I can think of for that scenario might be shut down sequence of the ECU. Perhaps there is a delay in the sequence to get shutdown completely done and ready for a restart. I could also be that I’m full of !@#$, just thinking out loud
Old Oct 6, 2019 | 10:39 AM
Steve N,'s Avatar
Steve N,
Originally Posted by Robtarra39
My 17 did the same thing with the oil light, brought it to the dealer and they replaced the oil pressure switched , hasnt come back on since
Ditto!
Old Oct 7, 2019 | 08:42 AM
jake24lt's Avatar
jake24lt
Weird you got a high and low oil pressure code when that bike doesn't have an variable oil pressure sender. Its only equipped with a switch that is either good or no good on pressure.
Old Oct 7, 2019 | 08:45 AM
mdrambler's Avatar
mdrambler
I'm wondering if this has to do with starting off quickly without the bike going through all the checks. The oil light seems to be the last light that goes off after the other lights go off when starting the bike!
Old Oct 7, 2019 | 12:23 PM
BrandonSmith
Where are you getting this information?
Old Oct 7, 2019 | 01:02 PM
lp's Avatar
lp
From the first post.
Originally Posted by TurkeyRun
Brought up the ECM codes and I've got:
- P0522 (low oil pressure)
- P0523 (high oil pressure)
- U0121 (loss of communication with ABS)
Take in mind, the ECM usually talks to it's sensors with 5 volts and a resulting, variable, voltage drop depending on what the sensor is doing.
If the sensor looses connection it might be read by a "high" voltage thus leading to a P0523 and when it's suddenly reconnected sees a low voltage and maybe P0522.
Totally spit balling and I might have them reversed. I forget.
Old Oct 7, 2019 | 01:42 PM
BrandonSmith
That is exactly my point, lp. I asked where Jake is getting his information about the oil pressure sensor because the oil pressure sensor DOES see variance in oil pressure - it is not a go/no-go sensor as Jake mentioned.
Old Oct 7, 2019 | 02:08 PM
lp's Avatar
lp
Brandon, I don't think it's a three wire sensor any longer. Since 17 it looks to be a switch. Not trying to correct you, just saying what we've seen and heard.
I thought in the switch there was a resister in parallel with the two wires or something that provides a less than 5 volt and greater than 0 volt reading so the ECM would know it's connected.
If the switch was Open, the line/ECM would read 5 volts (PO522). If shorted, 0 volts (P0523). Normal pressure, say 2 volts, and if low pressure, say 4 volts.
Something like that. Like I said, spit balling.
Old Oct 7, 2019 | 02:17 PM
strych9's Avatar
strych9
Grounded = closed switch = low
Open = open switch = high
Low and high are referring to reference voltage, not oil pressure.
