Screamin Eagle Header Pipes for M8
Old Nov 1, 2019 | 03:27 PM
skratch's Avatar
skratch
no, they are not even close. even so far as the end caps that fit on the screamin eagle pipes will not fit the cvo mufflers. and as royp has mentioned, the header pipes are the same, they contain the catalytic converter in the collector area.
Old Nov 1, 2019 | 03:36 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
Originally Posted by Donomics
Curious, Are the CVO pipes (for M8) basically the full screaming eagle system?
CVO's have different slip-ons, but header is the same as any other touring M8.
Old Nov 1, 2019 | 03:44 PM
Hoginedgewood's Avatar
Hoginedgewood
I've read some people say the M8 needs back pressure, sounds like you are describing a free flowing system that might cause performance issues.
I don't know just figure you might want to confirm or deny.
Old Nov 1, 2019 | 08:57 PM
BobRR's Avatar
BobRR
Here is a picture of the Screamin Eagle Header Pipe System. The cat is moved to the mufflers.
https://www.harley-davidson.com/stor...annon-mufflers
Old Nov 1, 2019 | 09:02 PM
BrandonSmith
Quality aftermarket vendors are well aware of the needs of the engines and how the exhaust affects them. Many "free-flowing" exhaust systems provide the necessary amount of backpressure, even with the removal of the catalytic converter, through proper design of the mufflers.
Old Nov 2, 2019 | 06:30 AM
ghanu's Avatar
ghanu
I would like to hear from anyone that has first hand experience with this exhaust system if there is any significant reduction in felt engine heat. That would be the reason for me to switch to this system as well as keeping the exhaust volume low, and keeping my warranty intact.
Old Nov 3, 2019 | 12:19 PM
bradsULtd's Avatar
bradsULtd
The SE High-Flow exhaust fits '17 and up touring...
Old Nov 3, 2019 | 01:38 PM
ghanu's Avatar
ghanu
Correct, mine is a 2020
Old Nov 3, 2019 | 04:38 PM
mjwebb's Avatar
mjwebb
man that is one expensive option as a solution to 'reduce' felt heat, talking ~$2000 if you have the dealer do the install and of course it would need to be tuned with the SEPST so more $$...does the heat bother you that much? I'd explore the options like mid frame deflectors and/or the cool flow fan..no epa Harley I've ever owned had heat bother me nearly enough to throw that kind of coin at the issue
Old Nov 4, 2019 | 12:53 AM
DandSPro's Avatar
DandSPro
Originally Posted by DandSPro
Fullsac header with the 4.5” SE slip on mufflers work fine
As I mentioned earlier . If you ordered the FullSac header, then you ordered the 4.5” SE mufflers ( for a factory header which means no converter in the mufflers )
that combination will work great , no heat issues )
