Voltage drop when starting
Old Jan 22, 2020 | 01:39 PM
skratch's Avatar
skratch
so what's your theory on the lithium batteries then? they absolutely do require a specific charger but use the same charging system on the bike.
Old Jan 22, 2020 | 01:46 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
and I rode about 15 miles to work.
I would venture to add that this is not far enough to put back what starting took out. Now the bike ought to start several times before flattening the battery but if all of your journeys are this then slowly you are flattening it.
Old Jan 22, 2020 | 01:49 PM
cbrenthus's Avatar
cbrenthus
http://www.thelongestlecture.com/cha...ormal-charger/
Old Jan 22, 2020 | 01:52 PM
cbrenthus's Avatar
cbrenthus
It's possible - I ride to work quite a bit, but I have to admit, I've lived closer to work in the past and never had this issue.
Old Jan 22, 2020 | 01:53 PM
Andy from Sandy
This statement is complete baloney and the proof is from Yuasa in the link below
"Unlike lead-acid batteries that use a liquid type of electrolyte, AGM batteries feature a chemical structure that doesn’t have a liquid type of electrolyte."
https://www.yuasabatteries.com/resou...n-agm-battery/
Once activated an AGM battery is maintenance free and cannot be topped up.
Old Jan 22, 2020 | 02:30 PM
cbrenthus's Avatar
cbrenthus
Down to 12.64 volts
Old Jan 22, 2020 | 02:43 PM
Andy from Sandy
Is that on or off the bike?
Old Jan 22, 2020 | 02:58 PM
cbrenthus's Avatar
cbrenthus
Off the bike - it went from 12.81 to 12.64 on about an hour and a half off the bike. I'm leaning toward bad battery caused by improper tender
Old Jan 22, 2020 | 03:46 PM
barneyboy's Avatar
barneyboy
Originally Posted by cbrenthus
My suspicion is that I fried both batteries by keeping them on an older, non-AGM battery tender junior.
May I ask how old was your BTJ? The reason I ask is mine is at least 15 years old, and I've always assumed it was safe to use on AGM. Should I be concerned, even though it's never fried an AGM battery?
Old Jan 22, 2020 | 05:43 PM
cbrenthus's Avatar
cbrenthus
It was much newer than 15 years, but if you've been using it regularly on an AGM for more than a year with no issues, maybe that isn't my problem. Quick update, the battery seems to have stabilized at 12.63V, and I checked my wife's 3 month old Pacifica with an AGM and its also 12.62V, and my 9 month old Jeep with an AGM is 12.20V, so I'm not really buying into the whole 12.8V is 100% and 12.6V is 75%. at 12.2, my Jeep is only around 40%.
So, back to the bike, I played around and check cables and found that while the nut on the starter cable was tight, I was able to get a good half turn out of it. I'm going to leave the battery out for the night, check voltage and maybe a few more cables in the morning, then try again. I'll update afterwards.
I picked the wrong year to try sober spring LOL
