17-18 Harley Clutch feel
Old Mar 6, 2020 | 10:00 PM
  #51
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
When I first rode a 2017 yes I noticed the clutch was different then on my previous bikes. Took a little getting used to but really never an issue. Now 26 months and 25k miles later it is the new normal and actually I would not want to change it. Works for me and I really doubt there would ever be a recall.
Old Mar 7, 2020 | 01:12 AM
  #52
JakeC7R's Avatar
JakeC7R
The clutch engagement sucks and the lever effort for a hydraulic clutch is stupid based on what is "standard" today. So I bought the AIM clutch slave and put on the softbrake lever to fix what I should not have to fix. But that is the price of admission on these bikes. So either you "get used to it" or "man up" or "get bigger forearms and don't complain" or blah blah blah no matter what excuses you give or shortcomings of the operator it still sucks the way it comes from the factory.
Old Mar 7, 2020 | 05:12 AM
  #53
Campy Roadie's Avatar
Campy Roadie
I'm filing a class action lawsuit on HD customers who don't understand they're the ones responsible for adapting to riding a Harley Davidson motorcycle.
Old Mar 7, 2020 | 10:39 PM
  #54
judgedelta's Avatar
judgedelta
The OP would be better served to go ahead and get an Aim Liteforce slave cylinder installed. I got mine when the recall came out on my '17 RG and the guys at the shop that put it in had to go ride it because it was so smooth and light, they didn't think it was disengaging.
Old Mar 9, 2020 | 08:34 PM
  #55
Long time rider's Avatar
Long time rider
Originally Posted by coolmac
Gentleman, with this thinking, you will be all a sheep. I wasted my time, to try to get something done.
The item that will fix this is the Damper Spring from a 2020 touring bike. It cost about $12.50 + tax from any dealer. It is a simple R&R procedure for anybody mildly mechanical. It retro fits 2017 & 2018 M8 bikes. When removing the clutch plates in the clutch basket the damper spring is the very last thing to come out. It helps to use a dental pick to remove the clutch plates. It makes a noticeable improvement in the friction zone. It does not look like a convention "spring". It actually looks like a round steel ring but has a convex side to it thus they call it a spring.
Old Mar 9, 2020 | 08:38 PM
  #56
lp's Avatar
lp
It's actually the Damper Spring Seat not the spring. It's thicker and will move the friction zone inward a little but do nothing to lessen the pull required or make the friction zone wider.
Old Mar 9, 2020 | 08:43 PM
  #57
BrandonSmith's Avatar
BrandonSmith
Aaaand, another very simple thing I learned this weekend: changing the position of the lever to be a little higher gives your fingers more grip and strength to pull and hold the lever. My lever was a little bit lower than the top of the grip. Now the top of the lever is level with the top of the grip and the pull is noticeably less. 2 minutes to do with a T25 wrench.
cclc28
Mar 12, 2019 08:47 AM
wschwurack
Touring Parts
Aug 26, 2017 09:16 AM
211Chuck
Sep 9, 2015 12:56 PM
Night Hog
Feb 27, 2011 01:29 PM
fxdbi
Jun 10, 2009 08:07 PM
