M8 noise
Old Mar 11, 2020 | 02:44 PM
Robert Sides's Avatar
Robert Sides
1st Gear
Default M8 noise
I have a 2018 breakout, it just broke 5k miles and I have been riding a 2013 street glide for the last 5 years. while riding the breakout i hear a noise from under the tank that i can only describe as metal rolling over metal or scratching sound but it only happens between 2k and 2500 rpm, does anyone know anything about this? the noise also goes away when i pull the clutch.
Old Mar 11, 2020 | 04:40 PM
dawg's Avatar
dawg
Noise going away when pulling clutch? Sure it’s not coming from primary, like an IPB?
Old Mar 12, 2020 | 08:07 AM
Robert Sides
1st Gear
IPB? i called around and a few say it could be the clutch bearing
Old Mar 12, 2020 | 10:45 AM
SoCaRider's Avatar
SoCaRider
There's a couple post on this forum about people complaining of upper valve train noise between 2000-2300 RPM.
II have a small amount of this.It is considered normal the master service tech rode my bike says I have a healthy M8.
on YouTube there's talk of this there's a company that sells a brass sleeve insert for the rocker arm where the bolt can chatter there could possibly be it.
Is a company that sells a product called rocker locker might look into
Old Mar 12, 2020 | 10:50 AM
Robert Sides
1st Gear
thank you, i have to get it in for the 5k service anyways so ill have them check it out while the warranty is still good, one mechanic thinks its the clutch bearing
Old Mar 12, 2020 | 09:28 PM
ROCKOUT Rocker Products
Sponsor
Rocker shaft inserts won't work on an M8.... the rocker configuration is different then previous engines... the inserts won't fit.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 13, 2020 | 12:14 AM
SomeOld Biker's Avatar
SomeOld Biker
If you only hear the noise in neutral and when you pull in the clutch and the noise goes away it is probally the inner primary bearing.
Old Mar 13, 2020 | 03:05 AM
Superdog3:16's Avatar
Superdog3:16
Rocker locker is for twincam engines
Old Mar 13, 2020 | 05:22 AM
dawg's Avatar
dawg
IPB?
Inner primary bearing
Old Mar 13, 2020 | 06:13 AM
jake24lt's Avatar
jake24lt
Default noise
FYI, you cant use rocker lockers on the M8 as the rocker assembly is completely different.
