Stock M8, here. No need for octane boost - the ignition timing and compression ratio doesn't demand it to prevent knock.
Those that mod the motor to boost power need to look at build formula for extra octane needed. Otherwise increasing octane can actually be harmful because the gas formulation has extra resistance to combustion that the engine can't burn, so you increase cylinder and valve deposits. Running the correct octane is important.
I also run non-oxy (no ethanol) gas. Even the M8 can tolerate 10% ethanol, it increases fuel consumption quite a bit. This means more frequent refueling, which is significant for only a 5 gallon gas tank. Non ethanol gas is also more stable and doesn't degrade as fast. So I don't add a fuel stabilizer in summer when I ride a lot.
In winter I always store the bike with Stabil fuel stabilizer - as with all my seasonal engines. They never fail to start in spring. I never run them dry, either. Older seals and gaskets dry out and crack causing leaks and air ingestion.
Gents the average rider or bike out there won't notice the difference between 91+ or 89 oct. on a road trip...
Last, never pass a gas station below half a tank.
Not sure thats correct. I thought the same thing last year when I started running the cheaper octane gas on my SE stage 2 bike. Pinged like crazy! That was also the same time I took my bike to have it dynod. MY guy called me and asked if I was running lower octane. He said he'd been trying to get the bike dialed in all day and it was still pinging. He wound up flushing the tank, putting the higher octane gas in and finished the dyno.
At least here in NC with our gase, thats what I experienced.
At least here in NC with our gas, that's what I experienced.
Agree with above...I can't even use 91 octane without pinging...I must use 93 oct and I never use octane boost...
I just took a road trip (on my car) up to Chicago and in Georgia I found , non ethanol gas but at 87 octanes, perfect for my other bike..but here in Central Fl., I get Non-ethanol 90 octane, and I don't hear any pinging (my old 78 triple did pinged and I would hear it ), and that is even after a cam upgrade, but I do have a hiccup in 1st gear I don't like and talked to a Dyno shop and they want "premium gas" didn't specify the octanage...so I was wondering if for dyno purposes I need to use gas 91-93 and 90 won't do it!
Most current Harleys require 91 octane minimum as per the owners manual.Why would you cheap out on fuel for a motorcycle is beyond me. I understand if you just cant find good fuel , but if you can....
Well non-ethanol I think is a lot better when you don't use the vehicle that often, then it is just one octane short of the 91 and since it is so humid here in Fl., (I already had a tank full of rust in my other bike using ethanol gas) it is a preventive measure and both of my bikes aren't pinging (my other bike actually calls for running on 87 Octane). That's why I use it, I was just wondering if an octane booster would help my ethanol free get to the 91 HD recommends. In my old 78 bike the 107 octane booster eliminated the pinging, and it was bad, it was a triple.
I keep some of this on hand, I trust it ... and took a bottle with me on my 4000 mile midwest road trip last year and used at times when there was some stations with somewhat questionable fuel quality, basically non top tier
At 11.5-1 my m8 runs equally well on 93 octane pump premium (up to 10% ethanol) as it does on 90 octane pure gas even in the heat. A box stock m8 should run fine on 89 even in the heat.
