Tick after cam ...zippers 468
Old Dec 21, 2020 | 08:43 PM
Socalledchad's Avatar
Socalledchad
Small video link of how loose something is..plug or broken wire..not sure . Will investigate further.
Old Dec 23, 2020 | 08:56 PM
porkster's Avatar
porkster
https://youtube.com/shorts/0PYU68MCRNc
that sounds like a loose plug or something, you didn’t remove those plugs did you?
Old Dec 23, 2020 | 09:33 PM
Socalledchad
After investigating I dont think that has anything with the engine tick. The plug wasn't loose and I didn't see anything going on in the wire. Plugging it back in I still have more play than normal up there. Ordered new plugs and wires.
Old Dec 23, 2020 | 09:48 PM
porkster's Avatar
porkster
Have you gone back and check the push rods?
Old Dec 23, 2020 | 11:13 PM
Socalledchad
Many have suggested an adjustment..but im not sure what that entails. I'd be curious what adjustment to make. Because i turned them the 3.5 recommended. The only thing would be if the engine wasn't 100% TDC or of the lifter plungers weren't to the top. Or, 3.5 is just not where I need to be. Would i.....
do another flat or 2 on all of them?
take a flat or 2 away?
Or pull them all and just redo the process.
Old Dec 27, 2020 | 06:22 AM
Steel Wheels's Avatar
Steel Wheels
Most lifters run about .200” total lash, with midpoint @ .100”. You can calculate movement by thread pitch without referring to instructions, but I can’t recall how. Some on the forum have done this; type in a search.
Old Dec 27, 2020 | 01:52 PM
SoCaRider's Avatar
SoCaRider
Lossen them up and ajust again best to start from point A no need to remove anything on the bike to do that, use a straw in your spark plug hole to fell the piston move for top dead center and just ajust the cylinder in front or behind it then repeat the other side
Old Dec 27, 2020 | 02:57 PM
hattitude's Avatar
hattitude
Originally Posted by mikeo33y
. When adjusting the push rods, make sure you wait about 30 min between each rod adjustment so that each lifter can bleed down properly. This is very important. otherwise your adjustment will be off.
FWIW....
Waiting for the lifter to bleed down is not for the pushrod adjustment.... the lifter bleeds down after the pushrod adjustment is made....
You want the lifter to bleed down before you rotate the engine. This alleviates any chance of the piston hitting a valve on the freshly adjusted lifter...
You can tell when the lifter has bled down, when you are able spin the pushrod in the lifter cup with your fingers fairly easily... Then it's safe to rotate the engine...
Treynolds03
Milwaukee Eight (M8)
21
Jan 23, 2022 10:59 AM
Oldskewl
28
Dec 8, 2018 08:25 AM
blair
Feb 24, 2015 12:42 PM
bikerlaw
EVO
Aug 25, 2010 11:33 AM
duranbayarea
Nov 8, 2009 09:38 PM
