Tuner or not
Old Mar 13, 2021 | 11:50 PM
Twotone2t's Avatar
Twotone2t
Stage IV
Default Tuner or not
I have JFG racing brand quiet slip ons and a K&N high flow intake. Was wondering if i need a tuner for a 2018 RG 107 ? Ig is running fine without the tuner. I have done my research and its 50/50. Some say m8 are very versatile and others says definitely a tuner. Anyone hear have any advice. Thanks in advance
Old Mar 14, 2021 | 05:28 AM
dave the welder's Avatar
dave the welder
Even if it runs good, it'll run better with a tuner. V&H's fuel pac is basic and Fuel Moto or TTS will be better.
Old Mar 14, 2021 | 07:38 AM
dajogejr's Avatar
dajogejr
If money is not tight/an issue, get a power vision from Fuel Moto.
It’ll run better...any future mods will lend nicely being able to tune them.
M8s aren’t as lean as the old twin cams, but you’re letting more air in and out, albeit not a TON, still good idea to maximize the parts you put on, even if the butt dyno doesn’t register much.
Old Mar 14, 2021 | 08:06 AM
Mofo67's Avatar
Mofo67
A tuner should make it perform better overall. As mentioned by a couple other members there are a lot of choices available. Since your bike is an ‘18 I guess it is out of warranty. If correct I would go with one of the recommended tuners. A power vision from Fuel Moto with their tune would be really nice and something you can build on later.
If you bike happens to be under factory warranty or you have a H-D ESP any tuner other than a H-D tuner will void your warranty.
Good Luck in your decision
drakenkade
May 24, 2023 12:16 PM
badcooky
Nov 17, 2017 03:25 AM
Webbie
General Topics/Tech Tips
Apr 1, 2017 03:20 AM
95ci springer
2014-2024 Touring Models
Mar 4, 2015 08:23 AM
oldmanbob
Apr 16, 2012 08:13 AM
