Sumping?
Old May 18, 2021 | 07:51 PM
jammerx's Avatar
jammerx
I didn't think you could sump the bike in the parking lot. Actually had to ride it and pretty hard too. As a rule, if there is a problem I check what I did first. If it is sumping in the parking lot maybe oil pump? I know you checked the oil ring... Were the piston oilers bolted down?
Old May 18, 2021 | 08:12 PM
mstrobes's Avatar
mstrobes
3 quarts out of the crank sensor.
Old May 18, 2021 | 08:23 PM
Agoober's Avatar
Agoober
User error 404.
Old May 18, 2021 | 08:27 PM
Quik's Avatar
Quik
Damn! I thought I was king around here with 60 ounces out of mine, 96 ounces…..that’s crazy!
Old May 18, 2021 | 08:55 PM
d_slat's Avatar
d_slat
I've seen a couple threads just like this one turn out to be busted gerotors in the oil pump.
Old May 18, 2021 | 09:02 PM
Quik's Avatar
Quik
If it put 96 ounces in the crank in a matter of 2 mins just idling then I would think it’s safe to say that bike has a MAJOR problem!
Old May 19, 2021 | 04:05 AM
SMR65's Avatar
SMR65
Yes and that would explain the clanging noise.
Old May 19, 2021 | 04:40 AM
Peak Seaker's Avatar
Peak Seaker
When installing the oil pump, you are supposed to install it with the mounting bolts loose on the cam plate (4), manually rotate the motor several times to ensure proper alignment and then torque. Could be that oil pump gears were not meshing to their liking and broke. I would be pulling
the cam chest apart for inspection before moving further. And as JammerX stated above, loose piston jets were an issue in the early M8's. You have to pull the top end to check those unfortunately.
Old May 19, 2021 | 05:14 AM
2013_FLHTK's Avatar
2013_FLHTK
This is an interesting video regarding the piston jets. I'm not saying this is the issue but it is important information to be aware of.
Old May 19, 2021 | 05:28 AM
dajogejr's Avatar
dajogejr
Something don’t add up. Did you guys check, by any chance…the crank sensor for oil prior to tear down/build?
You do mean 3 quarts, not 3 ounces, right?
I can see if you took the bike for a ride…but warming it up and not going anywhere…3 quarts? Wow…
