Compensator Problem?
Old Jun 11, 2021 | 04:58 PM
702's Avatar
702
Default Compensator Problem?
2019 SGS - 31k miles
Before I tear into it, I thought I'd ask for other opinions. This is a new issue that just recently appeared. Oil was changed less than 1k miles ago, but there wasn't an abnormal amount of metal on the drain plug magnet. I've inspected the engine mounts, they're good.
It doesn't have the clunk at startup or shutdown, but while accelerating or decelerating and passing through 2k rpm I'm getting a nasty vibration. It's not violent, but shakes the fairing like an old twin cam 88 at a stop light, or if you're old enough to remember - the 25 cent bed at the Motel 6. Pulling the clutch in at these times and maintaining 2000 ish rpm makes no difference. It also does it while stopped if I hold the throttle at 2000 rpm whether in gear or not. No abnormal sounds when I slip the clutch with the front brake locked up.
I think I hear a gravelly sound when this happens, but my hearing isn't what it once was.
The only other thing I've noticed is a hesitation at the 1-2 and 2-3 shift if I'm just poking along. Doesn't happen during hard acceleration.
Thoughts?
Old Jun 11, 2021 | 05:30 PM
Hawg Runner's Avatar
Hawg Runner
Easy to pull the cover and take a look inside, plus you can check the chain tensioner that way, only idea I have.
Old Jun 11, 2021 | 05:55 PM
702's Avatar
702
I ordered a locking bar, I'll wait till it gets here to open it up.
Macrunner
Milwaukee Eight (M8)
39
Apr 30, 2021 07:24 AM
TurboGliding
Sep 13, 2017 06:43 PM
jkane13
2014-2024 Touring Models
11
Mar 18, 2015 06:37 AM
palmpalm
Jul 28, 2014 04:31 PM
beary
Oct 1, 2007 04:10 AM
