M8 Header Pipe - What are you using?
Old Jul 19, 2022 | 07:52 AM
M Oclaf's Avatar
M Oclaf
Catalytic converter is non restrictive so removing it won't make it "louder", that said, I run a full cobra 🐍 pro chamber head pipe and neighbor haters, had the haters prior, did a tune and it sounds good to me, obnoxious, hardly...the moniker of "neighbor haters" is a bit of an embellishment, but I like my exhaust. Busting open the motor for a cam in these 114 M8's isn't something on my radar to achieve sound or a few more ponies. It's a Harley "road bike", ride it!
Old Jul 19, 2022 | 09:16 AM
h7009's Avatar
h7009
racertb, keep your stock header, there is nothing wrong with it (use the saved money for something else). Cut the "cat" out with a 12" drill bit from Home Depot. You will get a little more sound with those mufflers. But mostly a loss of heat from the Cat, I measured before and after with a temperature gun dropped 125 degrees!! Good luck whichever way you go, CSM-H
Old Jul 19, 2022 | 02:28 PM
racertb's Avatar
racertb
Thanks, I like the neighbor haters and a little more volume would be nice but the heat is the main issue so that's good to hear.
Old Jul 19, 2022 | 02:39 PM
JHC210's Avatar
JHC210
Fullsac is the way to go.
Old Jul 20, 2022 | 03:43 PM
racertb's Avatar
racertb
So the only option for the M8 on the fullsac website is $799? No thanks 👎
Old Jul 20, 2022 | 05:10 PM
mjwebb's Avatar
mjwebb
but you have to pay more for "the way to go"..I think..
Old Jul 20, 2022 | 07:36 PM
Matt0144's Avatar
Matt0144
5th Gear
Vance and Hines power duals with Vance 450 torquers and S&s 465 cam
Old Jul 21, 2022 | 02:16 PM
Gizmo83's Avatar
Gizmo83
How is the V&H Power Dual header on the M8 in terms of power?
Old Jul 21, 2022 | 02:19 PM
Matt0144's Avatar
Matt0144
5th Gear
bike feels great. I haven’t had it on a dyno. And I went from stock to all these parts at once. Bikes ride and sounds great
Old Jul 24, 2022 | 06:33 PM
chief1600's Avatar
chief1600
FM 2/1/2 SS head pipe with S&S GNX slip ons. Sounds good now. Will sound better when I do cams next spring!
