Loose manifold
Old Feb 21, 2023 | 11:57 AM
OldMike's Avatar
OldMike
Originally Posted by Jsndvll
Yeah, it's just loose when the air cleaner is off. But it kinda makes sense seeing how the manifold sits in the motor - there's nothing holding it bolted down really. Do you think i'll need new gaskets for the manifold or will i be good to go with the new air cleaner? I can't recall having any problem with it before i started picking the bike apart.
This is the point where I check and snug down the manifold flange screws. OR, like a lot of people do, get a SE 55mm manifold because of the bad things that can actually happen with the stock plastic manifold. Warping, leaking and cracking.
Old Feb 21, 2023 | 03:01 PM
PureHybrid's Avatar
PureHybrid
When you get it fired back up, lightly spray some carb cleaner around those joints at the intake ports. If there's a leak the idle will change
Old Feb 21, 2023 | 03:10 PM
chopper_man's Avatar
chopper_man
100% normal. They require the air cleaner backing plate bracket and support to secure them. That is the anchor point to the motor/heads/rockers depending the bike you are working on.
Old Feb 22, 2023 | 09:36 AM
Since 1968's Avatar
Since 1968
My lack of memory on this was bugging me, so I went back to YouTube University and watched a manifold installation video. It's as chopper-man and 702 said, the movement is normal when the air filter or in some cases bracket is removed. However, the movement in your video is excessive, and about what mine was before installing the manifold backing plate for alignment purposes. With the tank still off and the backing plate (or support bracket for some) you then tighten the four screws (go ahead, call them bolts). If you were to remove the backing plate at this point there should be no sort of flopping around like your video. Based on all this, you probably don't need new rubber seals. I would try reinstalling and tightening and then checking for leaks. Go to YouTube and search for this: "install S&S 55mm manifold in M8"
Old Feb 22, 2023 | 08:32 PM
propflux01's Avatar
propflux01
Does anyone know, if you buy the aluminum manifold, does it come with the seals that mate the manifold to the cylinders, or do you have to order those extra through HD ?
Old Feb 22, 2023 | 08:49 PM
mjwebb's Avatar
mjwebb
https://www.harley-davidson.com/us/e...old/p/27300167
https://serviceinfo.harley-davidson....3?locale=en_US
Old Feb 22, 2023 | 10:09 PM
Max Headflow's Avatar
Max Headflow
Stock M8 manifold is plastic. It's not going to be held as tightly as a cast aluminum one.. Hopefully you wiggling it up and down has compromised the seal. Might be worthwhile to disassemble and inspect..
Old Feb 22, 2023 | 10:22 PM
propflux01's Avatar
propflux01
Then the HD version does not come with manifold O rings. Perhaps the S&S version does.
Old Feb 22, 2023 | 10:34 PM
mjwebb's Avatar
mjwebb
according to the instructions as well as the OEM parts finder tool it looks like flange / seal units ..the seals are $5 apiece to order
Old Feb 23, 2023 | 08:38 AM
Since 1968's Avatar
Since 1968
I bought an S&S one from Dennis Kirk and it did not come with the seals and O rings. I paid about $21 for the 4 bits from HD.
RET_SCPO
General Topics/Tech Tips
May 18, 2020 09:41 AM
Scott Shepherd
2018+ Softail Models
Aug 12, 2019 09:14 AM
Curbside
Jul 2, 2019 09:55 PM
rapp76
Jun 26, 2013 08:32 AM
cruzmisl
Sep 16, 2012 07:42 PM
