M8 stage kits
Old Aug 21, 2023 | 01:57 PM
JaTimms's Avatar
JaTimms
Stage I
Default M8 stage kits
Kinda new to the stage 1-4. My question is if I get the stage 2 done, later on I want the stage 4. Do the dealership just add what need be added to make it a stage 4 or all new parts? I know it's a dumb or.crazy question. Thanks in advance
Old Aug 21, 2023 | 02:07 PM
mjwebb's Avatar
mjwebb
Harley's website explains how all their Screaming Eagle stuff works .. very informative and educational for their performance upgrades .. would be the best place for you to start investigating
Old Aug 21, 2023 | 02:26 PM
TriGeezer's Avatar
TriGeezer
Welcome to the forum.
To answer your question…it depends upon what your stage 2 is.
Old Aug 21, 2023 | 02:37 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
HD does it like this
Stage 1: Exhaust and Intake.
Stage 2: Cam upgrade, sometimes manifold.
Stage 3: Bigger Cylinders and Pistons.
Stage 4: Head work and related modifications.
Stage 2 with a bolt in cam, to stage 4 will probably include swapping to a cam that requires higher than stock lift springs, and a large intake manifold.
So from standard bolt in stage 2 to stage 4 you will probably need a new cam, heads, 64mm manifold, cylinders, pistons, performance lifters, and many other new parts.
Old Aug 21, 2023 | 06:18 PM
SMR65's Avatar
SMR65
and different tunes on Stages 1 thru 4
Old Aug 21, 2023 | 07:18 PM
jlasoftail's Avatar
jlasoftail
If you know you’re going to do upgrades later, you can start gearing yourself towards that now. Some cams have lots of room to grow when it comes to displacement. Also, maybe you only get slipons now, and you can do a head pipe later. Any decent breather should work for both. Then you need to think about what tuner you will use.
If you plan on keeping warranty, some of those decisions will be made for you…
jcannady
2018+ Softail Models
Mar 4, 2021 07:57 AM
anynamewilldo
Jun 29, 2019 09:00 PM
sifularson
Apr 11, 2015 05:40 PM
Swamphunter
Screamin Eagle CVO Models
Jul 19, 2009 09:24 PM
gilmour68
May 20, 2007 10:08 AM
