S&S Lifter Failed - Replace with what??
I do not believe they are splitting the cases or removing the heads/cylinders. I will ask why they believe those steps are unecessary.
I fully intend to discuss the differences with my mechanic, but I prefer to go into that conversation with some knowledge and understanding.
No burnouts, no clutch dumping, no hooliganism whatsoever. Oil and filter have been changed regularly and in fact all three holes were changed just under 3,000 miles before this happened. Yes, I have the paperwork documenting this.
Since when is 12,500 miles high mileage? One of the reasons I replaced so many stock parts with S&S parts was to ensure something like this did not happen.
It’s sucks that it failed, but it’s still in the high performance parts category and ok, you didn’t hooligan it, but S&S nor anyone here can confirm that fact, and even if they warranty your lifters it’s a small portion of the total rebuild dollars, and while the lifter might have been the failed part, that caused the damage, there may be another factor that caused it.
This stuff is just part of the buy in when you modify engines, stone stock may be boring but it’s meant to last the longest.
edit, the only true way to is to split everything and inspect everything bearing and surface, both rod ends, crank etc.
I have to replace at least all four lifters and my cam. S&S denied my warranty request because it has been 16 months since the 128" kit was installed and the lifters are only warrantied for one year.
As I am replacing the lifters on my own dime, I don't want to use S&S lifters. This is both because I don't want to give S&S any more of my money, and because I no longer trust their lifters.
I'm looking a Feuling lifters and there appear to be four that fit my bike:
1. Feuling HP+ for $190
2. Feuling Race Series Short Travel for $299
3. Fueling Race Series Standard for $299
4. Feuling Race Series Oversized (in various amounts of oversizing) for $299
Which Feuling lifters do I want, and why?
Thanks for your input.
Seems like a bit of a crapshoot. I've never had any problems with S&S lifters, though I know a few people that have.
I've had success with CompCams V-Thunder lifters, which are just a Chevy lifter. I think if I was going to buy lifters now (and I do need a set) I would go on E-bay and get Hyline Johnson lifters. $103.92 a set is a pretty good price. WFO Larry wants $179.00 for the same thing.
https://www.ebay.com/itm/12159841331....c100903.m5276
No offense intended. Hopefully none received.
Paul
http://www.larrysmotorcyclemachine.com/lifters.html
Paul
That small debris from a hardened part failures (like a cam or follower) can hide in some gnarly places, depending on how long the engine ran while shedding this metal. I speak from experience, and the unfortunate consequences
