Oil Archive (no new posts) An archive of oil related questions and comments.
How much fluid in primary?
Old Jun 14, 2007 | 12:55 PM
Z_Stingray's Avatar
Z_Stingray
Default How much fluid in primary?
Afriend and I are uncertain how much fluid to put into the primary when changing the fluid. He has a 2002 Electra Glide Standard and I have a 2007 Street Glide. My owner's manual says to add 38oz. to a wet primary. My friend didn't receive an owner's manual with his newly purchased bike.
I've read one here that a variety of volumes are added to the primary, but I was uncertain the year and model of the bikes related to the volumes. Some say 24, 36, 38oz., and some say to just dump a quart in and close 'er up.
I know the proper volume should be even with the clutch springs, but it's hard to see anything near the bottom of the clutch on a 2007.
Any recommendations on primary volume levels for a 2007 Street Glide (FLHX)?
Any recommendations on primary volume levels for a 2002 Electra Glide Standard (FLHT)?
Old Jun 14, 2007 | 12:58 PM
Hdbiker1450's Avatar
Hdbiker1450
Default RE: How much fluid in primary?
Changed mine the other day, and seems to me that on our 02 RK it was 32oz. Should be the same on the 02 EG.
Check your owners manual. Should have all the specs there.
Old Jun 14, 2007 | 02:30 PM
EZ2Rider's Avatar
EZ2Rider
Touring bikes (TC88) take one qt.
Harley has varied the amount on other models, depending on how much trouble they had with clutch drag from too high a fluid level. The correct amount is, I guess, the most (up to a qt.) it will take without clutch getting clunky. Many report using the "bottom of the clutch basket" method through the derby cover that their bike takes more than what their manual says it should.
It lubes the chain and cools the clutch plates through the "splash" method, rather than being under pressure like the crankcase oil. The amount is NOT critical if it is enough to accomplish those two things and doesn't cause the clutch to drag.
EZ
Old Jun 15, 2007 | 12:13 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Just dump a quart in there.......
Old Jun 15, 2007 | 10:11 AM
billnourse's Avatar
billnourse
2005 service manual calls for 32 oz. 2007 service manual specifies 38 oz.
Bill
89FLHTC
EVO
14
May 2, 2016 04:44 PM
big TYME
May 10, 2012 10:20 PM
lhgdale
Apr 23, 2012 07:09 AM
pauletich
Jun 19, 2006 05:21 PM
jube455
13
Apr 24, 2006 09:00 AM
