Oil Archive (no new posts) An archive of oil related questions and comments.
Mobile 1
Old Jun 5, 2019 | 05:45 AM
470004's Avatar
470004
Originally Posted by shanneba
I see Mobile 1 mentioned often. Never seen any around here.
Must be a Mobile, Alabama local brand.
Mobil 1 motorcycle oil is a good oil.
I often see it in Walmart. It is in the oil section, but not mix together with the oil used for auto. You need to look around that area for it.
Old Jun 5, 2019 | 09:32 AM
user 7172984932's Avatar
user 7172984932
Mix 1 part Mobil V-Twin. 1 part Amsoil. 1 part Redline. 1 part Spectro.. You should be OK.
Old Jun 5, 2019 | 09:36 AM
xcbullet's Avatar
xcbullet
Somebody part crazy.
Old Jun 5, 2019 | 01:22 PM
hd4evr2008's Avatar
hd4evr2008
Mobil 1 is great oil......but, skip the 20w 50, and go with this. Additive package is very good, and Walmart has it in 5 qt. jugs for $22.88.
Old Jun 5, 2019 | 01:37 PM
xcbullet's Avatar
xcbullet
Just went from the 15-50 to the 20-50 and the 20-50 is better.
Old Jun 5, 2019 | 01:41 PM
lewk's Avatar
lewk
Originally Posted by hd4evr2008
Mobil 1 is great oil......but, skip the 20w 50, and go with this. Additive package is very good ...
I used it for a while and my top-end was noisier than when I used other oils. Not sure why, may be this is a thinner oil?
Hmmm, better in what way?
Old Jun 5, 2019 | 01:52 PM
xcbullet's Avatar
xcbullet
No top end noise and lifter doesn't bleed down.
Old Jun 5, 2019 | 05:38 PM
hd4evr2008's Avatar
hd4evr2008
Thousands of miles on the 15w 50 with no problems.
Old Jun 5, 2019 | 05:46 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I run it in all my cars. Checked my CR-V valve lash at 100K. Looked like new under the cover. The intake was dead on. Exhaust about .001 tight.
I run Mobile 1 15W-50 in the bike. Fifty K on it. Still runs like new. I use Formula + straight weight non detergent gear oil in other two holes. No filters, so you do not want a detergent oil in them.
Old Jun 5, 2019 | 06:06 PM
HKMark23's Avatar
HKMark23
A point to consider; perhaps its important, perhaps not:
ZDDP is good for engines. Most "automotive" oil blends have had ZDDP levels greatly reduced in order to placate the EPA and preserve catalytic converters. Oils blended specifically for diesel engines and motorcycles remain high in ZDDP. Sadly, these latter oils are rarely on sale at Walmart.
