Oil Archive (no new posts) An archive of oil related questions and comments.
Mobile 1
Old Jun 5, 2019 | 07:48 PM
hd4evr2008's Avatar
hd4evr2008
Mobil 1 15w 50 has ZDDP....
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
Mobil One 15w 50 levels............phosphorus-1200 ppm.......zinc-1300 ppm
Mobil One 20w 50 levels............phodphorue - 1600 ppm......zinc - 1750 ppm
That's "parts per million" ^^^^ not a whole lot of difference.
Mobil 1 15W-50 also contains higher levels of anti-wear (ZDDP or Zinc DialkylDithioPhosphate)
Lots of Harley owners have been happily running 15w 50 for years. Google it and you'll find a lot of info. The 15w 50 has a great additive package which is VERY SIMILAR to the 20w 50. Really the only difference is the 20w 50 is wet clutch (for metric bikes) compatible, and it says V-Twin on the bottle. Your money, your choice, but the 15w 50 will do a great job in your Harley engine.
Old Jun 5, 2019 | 08:05 PM
shanneba's Avatar
shanneba
If Mobil 1 15w-50 had higher levels of ZDDP it would have higher levels of zinc and phosphorus.
Old Jun 5, 2019 | 08:59 PM
hd4evr2008's Avatar
hd4evr2008
I meant higher levels than "car oil", not higher levels than the 20w 50. The 15w 50 additive package is better than a lot of so called "motorcycle oils". But, like I said, your money, your call. The 15w 50 is what I'll stick with.
Old Jun 6, 2019 | 01:06 AM
xcbullet's Avatar
xcbullet
I've ran alot of the 15-50, only reason I got the 20-50 it was on clearance at $6. This is the first time with no top end noise that I can hear. Plan to try VR1 after use up the M1 to see if it's as good. Just don't think I'll want to run the VR1 in cold temps though would rather have synthetic then.
Old Jun 6, 2019 | 02:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The big reason for needing ZDDP is for engines with flat tappets.
Last time I checked, no Harley has flat tappets.
Nobody is wearing their engines out by using automotive 20w50 of any brand.
There is no such thing as Mobile 1...
Old Jun 6, 2019 | 02:22 PM
perki48's Avatar
perki48
I wonder if using straight STP would quiet the top end for those who are worried about it?
Old Jun 6, 2019 | 02:33 PM
xcbullet's Avatar
xcbullet
I've worn parts and replaced them, cams and rocker arms. Have had cam bearings fail from first owner, mostly run on syn3 I believe. Ya parts don't wear what dream world are you from.
Old Jun 6, 2019 | 05:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I stated that engines are not wearing out from using automotive 20w50.
Parts certainly wear out, and no oil is going to be the magic cure.
No reason to get snotty here. It`s only an oil discussion, be civil.
Old Jun 6, 2019 | 05:39 PM
xcbullet's Avatar
xcbullet
Sounds like double talk to me.
Old Jun 10, 2019 | 05:39 PM
hd4evr2008's Avatar
hd4evr2008
Here's a virgin oil sample of each, tested by CTC Analytical Services of Phoenix, AZ.
Silicon: - M1 15W-50: 9ppm .........M1 V-Twin 20W-50:10ppm
Boron: - M1 15W-50: 228ppm .........M1 V-Twin 20W-50: 188ppm
Sodium: - M1 15W-50: 13ppm......... M1 V-Twin 20W-50: 3ppm
Magnesium: - M1 15W-50: 43ppm....... M1 V-Twin 20W-50: 538ppm
Calcium: - M1 15W-50: 2464ppm........ M1 V-Twin 20W-50: 1899ppm
Zinc: - M1 15W-50: 1315ppm......... M1 V-Twin 20W-50:. 1352ppm
Molybdenum: - M1 15W-50: 90ppm...... M1 V-Twin 20W-50: 0ppm
Looks pretty good to me.
