Oil Archive (no new posts) An archive of oil related questions and comments.
47 knucklehead oiling issues
Old Aug 17, 2020 | 11:20 PM
Michael Shields's Avatar
Michael Shields
Stage II
Default 47 knucklehead oiling issues
Hello and thanks in advance for any help. I have a 47 knucklehead and am having some issues with top end oiling. Getting oil from cam.chest up to rockers but little to no oil to the rockers or valve spring area. Found a few pushrod tube leaks and have new tubes and seals ordered but not sure that is causing my issue. I know its controlled by vacuum. But would a small pushrod leak not pull any oil into the valve spring / rocker bucket area? Thanks for any ideas or help
Old Aug 25, 2020 | 09:45 PM
bustert's Avatar
bustert
vacuum????? hummm
do you have the fsm?
at lower speed, there is a by-pass circuit, been awhile but i think it is controlled by centrifugal force. does oiling improve with increased rpm?
i have some info in my library. drop me a pm.
Old Aug 25, 2020 | 09:58 PM
Michael Shields
Stage II
I got it figured out, it turned out being the rocker shaft oil hole filled with sludge and not getting oil to either valve on front head. Pulled heads heads and cleaned everything. Working on new valves, springs and guides while there off. Thanks for the help.
Chris Sigo
Shovelhead
Feb 7, 2019 06:44 PM
bobsemp
Ironhead
Apr 6, 2008 04:37 AM
dwn1383
Panhead
14
Mar 24, 2008 03:03 PM
wreck74
Panhead
Jul 25, 2007 10:55 AM
Acell
Jul 25, 2007 10:31 AM
