Anyone tried this stuff?
I base my beliefs in synthetics on tear downs of countless engines powered by gasoline, diesel, and even propane and natural gas over a wide spectrum of applications and duty cycles, in environments from -40F to 120F. Some of these customers engines I actually built, and maintained through a service life of over 10,000 hours.
Does this mean I am completely right about all of my beliefs? No. I only know what I have seen after gathering the engine data, total gallons of fuel consumed (calculated by the ECM), and oil sample analysis.
I still believe that Valvoline, and many other conventional oils provide great service. I prefer synthetics based on a long career dealing with engines, but I am never going to vehemently condemn someones product choice. I still believe that if they do their part, and change it at correct intervals, that their bike will last a long time.
There are SO many other factors that go into engine wear, and reading a biased "report" on the internet may not reveal instances of improper air filter care. One teaspoon of dirt ingested from improper air intake sealing will wipe out an engine slowly over time and the oil will get blamed. I have seen things like this too many times to count, with a customer screaming WARRANTY! Overfueling, and improper tunes, components, and valve adjustments come into play as well.
I know this is futile, but I am bored. Just trying to help, really.
But that said, I agree synthetic vs conventional is more a preference thing.
The bigger issue really is motorcycle oil, synthetic and conventional, that's missing beneficial friction modifiers because it's designed for use in motorcycles that share a sump and friction modifiers don't work in wet clutches. Harley's don't share a sump. Why run motorcycle oil in your engine? Especially when it costs more than oil WITH these beneficial friction modifiers. It makes no sense!
The argument is made because mc oil has higher levels of zddp than automotive oil. This is true. But so do race oils because they're not subject to EPA regulations that limit zddp in regular automotive oil. And race oils also have the friction modifiers motorcycle oil doesnt have AND in most cases is cheaper or at the very least comparable to motorcycle oil. I cant explain it any better yet people are going totally off topic here and totally ignoring the obvious!
No wonder my inbox fills with people asking about this. They don't want to deal with all the bs bashing just because they want to run the best TYPE of oil especially if it's cheaper besides. Some of them end up running VR1. Some other race oil. Even synthetic race oil. Or semi synthetic. Anything but motorcycle oil.
I don't even think VR1 is necessarily the best race oil. But the best cost effective one that does the job better than any motorcycle oil. Especially when changed at more appropriate intervals to avoid contamination.
VR1 is way more popular in Harleys than most of you think. Probably the most popular choice by those that have come to the logical conclusion that motorcycle oil is not the best choice here. Synthetic or conventional.
I continually post this because like you, some continually miss the point of what I'm saying and my inbox says there's much more interest and many more people that agree with me than you care to admit. But I get it. No one wants to hear the oil their running is not only a waste of money but not even the best TYPE of oil to run in a motorcycle that doesn't share a sump.
Maybe one of these days someone will actually attempt to answer the question I keep asking and explain why they think motorcycle oil is a good option here. I doubt it tho. 1. Because they can't 2.The hit and run approach makes them feel like they've accomplished something and 3. It's easier to bash something they don't understand or can't explain rather than have any type of intelligent discussion about it and risk losing.
But y'all have a good day. No hard feelings here. I'm a big boy. Just trying to pass along what I've learned to those who are genuinely interested in and open to learning or having an intelligent discussion.
Oh and how are UOAs by independent labs biased? It's about as scientific and UNbiased as it gets. What's biased are tests done by Amsoil that say Amsoil is the best. Wow. Now there's a surprise. I don't quote Valvoline or ask them what the best oil to use is. And yes people actually ask oil manufacturers what oil is the best. Like Amsoil will answer with anything but Amsoil.
If you look here: https://www.mobil.com/en/lubricants/...v-twin-20w-50/
you'll see Mobil 1 V-Twin 20-50 has 1600 ppm Phos and 1750 ppm Zinc whereas regular Mobil 1 has 800 ppm Phos and 900 ppm zinc.
If this sort of thing matters to you then its something to consider when contemplating saving a few bux by purchasing automotive Mobil 1 on sale at Walmart, for example. You can always resort to additives but where's the saving then ?
You might want to do a bit of research before going to powdered additives. I vaguely recall reading some warning advice with respect to moly additives back in the day when it was a powder but can't really offer more than that.
Merry Christmas.
Moly is one such friction modifier. Good for motor. Bad for wet clutch.
Seems I'm not the one that needs to do research. I've done plenty.
Running motor oil in all 3 holes is not the best option either and is only done by those too lazy to run gear oil in the tranny and primary fluid in the primary.
Merry Xmas and Happy New Year to you as well.
Also, I don't consider those Harleys but whatever. Just another reason why. Too bad for them they have to use motorcycle oil. Real Harleys don't.
You're grasping at straws to prove me wrong about Harleys and motorcycle oil. Not going to happen. Your time would be better spent learning about oil.
I don't consider the livewire a Harley motorcycle either. All of them are failed experiments.
Blah blah blah blah blah. My oil is better than your oil. Blah blah blah blah blah blah. Nobody cares! This has issue been discussed on this forum at least ten dozen times already. Blah blah blah blah blah.
Does anyone force you into the oil forums?Obviously others appreciate the info and get something out of it and obviously DO care. So don't say nobody cares just because you're a nobody that wants to be heard.
Seriously, the only people that look stupid are people who respond with the same drivel you just did in every oil thread rhat pops up cuz guess what...? Nobody cares.
My inbox is full of people who care and have changed the oil they use as a result. Some have posted in this very thread and others like it they care and have changed their oil. All you do is make it necessary for more threads like it because they don't want to sort thru your mindless drivel to get the answers they're looking for. This thread is a perfect example. It got turned into everything but the original topic of the thread by people who had nothing intelligent to add because they know absolutely nothing about it but felt the need to post anyway with the same mindless drivel. Pretty pathetic really.
Sorry if it makes you feel inferior. It's not my intention.
Correction. Danny is drivel poster number one. I kept track for awhile and he was the first responder to 13 of 20 oil threads.
Gotta give credit where it's due!
I did not say that the UOAs were biased, I actually said the internet reports were (reports from ALL of us here)
Go ahead post your rolling eyes. I was just trying to have a civil conversation, and look at both sides, but as usual you have to act like you always do in the end. Good for you an all of your purported "followers" that send to your Inbox.
