Oil Archive (no new posts) An archive of oil related questions and comments.
64oz in Primary?
Old Oct 29, 2021 | 10:16 AM
eljefe6's Avatar
eljefe6
4th Gear
Default 64oz in Primary?
I recently took off my Primary cover, derby cover, cam cover and transmission cover to get powder coated. So of course I drained all the fluids, and since the covers came off, a little bit more fluid came out.
When filling my primary, the service manual says about 40oz for a dry fill. (being that I had the cover off, this would be a dry fill). And to fill it until it just about reaches the pressure plate outer diameter. Well, 64oz in and it still has not reached the OD of the pressure plate.
Normal for a completely dry fill?
Old Oct 29, 2021 | 10:23 AM
TriGeezer's Avatar
TriGeezer
It’s only supposed to touch the bottom of the clutch basket.
Old Oct 29, 2021 | 11:42 AM
nevil's Avatar
nevil
Are you filling it with the bike in a vertical position or on the jiffy stand? And what bike are you working on?
Old Oct 29, 2021 | 12:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
You need to let us know what model and year bike you are working on....
Is the drain plug installed?
Forget about dry and wet fill etc.
Stand the bike up vertical, fill the primary until the lube level just touches the outside diameter of the diaphragm spring on the clutch.
This level is the same for any big twin wet clutch since mid `84.
Old Oct 29, 2021 | 07:32 PM
mjwebb's Avatar
mjwebb
did you put the drain plug back in before filling?
Old Nov 4, 2021 | 07:17 AM
Crispy's Avatar
Crispy
Well, did you figure it out?
Old Nov 5, 2021 | 09:41 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Looks like the OP never came back to see if anyone answered his question...
Rogue1
Oct 7, 2020 04:53 PM
hog95023
Jun 30, 2013 04:11 PM
Misbehaven
Jul 31, 2011 05:09 AM
wingnutt
Jan 9, 2008 01:40 PM
dert
Sep 21, 2005 12:17 PM
