Oil Archive (no new posts) An archive of oil related questions and comments.
Primary Level
Old Nov 2, 2007 | 09:10 AM
06ClassicRider's Avatar
06ClassicRider
Default Primary Level
This is a bit of continuation frommy earlier post. In making sure the fluids are at the appropriate level in the primary, namely just above the edge of the clutch pack circumference, Icut a strip ofstiff paper to the radius of the clutch pack in order to measure if the oil is above the circumference line. I place the one end on the adjuster screw and hang the strip down into the oil. My question, short of trusting the amount poured in based on the bottle gauge, are there other tips of how to make sure you have the right amont of fluids in the primary? I developed this method after straining to use a flashlight and look into the derby cover hole. How silly was that [:-]?
Old Nov 2, 2007 | 10:18 AM
GTK's Avatar
GTK
Default RE: Primary Level
Drain primary good and put 1 qt in and forget it.
Old Nov 2, 2007 | 10:19 AM
Phrogman's Avatar
Phrogman
There's nothing really silly about using a flashlight, after all light is reflected off of oil. My usual method is to simply lean the bike to the left until I can see the fluid. If I can't see it when the bike is upright, it isn't full since I can plainly see the bottom of the clutch pack through the derby cover.
Old Nov 2, 2007 | 10:24 AM
Mikeeeeeeeeee's Avatar
Mikeeeeeeeeee
"Moderator & Connoisseur of Ice Cream"
Hi,
Drain out old.
Install 1 qt.
I'm moving this thread to the section it belongs.
Trace will remain here.
Old Nov 2, 2007 | 10:28 AM
Big Peter's Avatar
Big Peter
ORIGINAL: GTK
That's the way to do it
Old Nov 2, 2007 | 12:18 PM
EZ2Rider's Avatar
EZ2Rider
Gee Mikeeeeeee, that's what I said too but got a correction!!!!!!
EZ(still think its right though)
hardheaded
Oct 17, 2018 10:44 AM
TriGeezer
Apr 20, 2016 04:22 PM
J.Ryan
Sep 26, 2013 03:57 PM
BigDawgQC
Dec 5, 2012 07:56 PM
RoadKingon
Apr 25, 2007 10:42 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
