Oil Archive (no new posts) An archive of oil related questions and comments.
oil flow question
Old Mar 16, 2008 | 08:02 AM
rideevo's Avatar
rideevo
Default oil flow question
Hi,
Manual says evos are gravity fed to oil supply side of pump, how does oil gravity feed on sump
below trans?Just wondering
Old Mar 16, 2008 | 09:56 AM
rbabos's Avatar
rbabos
Default RE: oil flow question
Substitute gravity with suction, just like a typical wet sump system.
Ron
Old Mar 16, 2008 | 10:04 AM
rideevo's Avatar
rideevo
Hi Ron, thanks for the reply i was thinking that, but Manual says evos are gravity fed to oil supply side of pump? i guess the manual in not always correct
Bob
Old Mar 18, 2008 | 12:35 PM
rbabos's Avatar
rbabos
Not sure about your first question. To me , you were asking about two different sumps. Evo is gravity feed to the pump inlet. This is known as a dry sump system (seperate tank). Sumps that are below the pump use suction (not gravity)to prime the pump, as in the A motors or your car.
Ron
Old Mar 18, 2008 | 05:08 PM
rideevo's Avatar
rideevo
thanks for the reply , i guess the evo oil pump sucks
Wi_Duker
Apr 23, 2017 04:09 PM
jaymansfield
11
Oct 17, 2015 08:51 PM
ozzie65
General Topics/Tech Tips
Jan 27, 2009 09:41 PM
rbabos
Exhaust System Topics
Aug 5, 2008 03:40 PM
carlo
Nov 24, 2007 07:58 PM
