Oil Archive (no new posts) An archive of oil related questions and comments.
engine oil leak
Old Dec 21, 2008 | 04:50 PM
vanbanks's Avatar
vanbanks
1st Gear
Default engine oil leak
I removed the crankshaft pulley and the alternator rotor. Engine oil is leaking out through the splines on the crankshaft. I had the same problem with an S&S engine. This engine is an Ultima. What is causing this and how can it be stopped. Thanks.
Old Dec 21, 2008 | 05:37 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Bad seal... kinda rare to wipe it out though, unless it was installed incorrectly....
Old Dec 22, 2008 | 01:11 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
+1 on the seal. Make sure you make a note of the orientation because I have seen guys put them in backwards and they will run for a short while then usually leak. Check the bearing as well. When you have it apart before you remove the bearing pull up and down on the shaft and see if any oil squeezes out between the bearing and the case. (if it does it means you have a case issue or incorrect fitment).
If it were me I would replace the bearing and be sure to check the shaft for any scoring.
Old Dec 22, 2008 | 04:47 PM
vanbanks's Avatar
vanbanks
1st Gear
The engine only has 150 miles on it. The oil isn't leaking around the seal. The oil is coming between the sproket shaft spacer and the sproket shaft.
86evokid
Shovelhead
16
Jun 21, 2018 04:13 PM
joewg3
Jan 5, 2015 07:16 AM
RBL
EVO
Feb 17, 2011 12:49 PM
fiddledicksr
Jul 20, 2009 09:21 PM
2Shakes
Exhaust System Topics
Apr 11, 2009 10:12 AM
