Oil Archive (no new posts) An archive of oil related questions and comments.
Motul 7100
Old Feb 25, 2009 | 02:55 AM
italfatboy's Avatar
italfatboy
Default Motul 7100
I'm planning on doing my own oil change soon. Just wondered if anyone has used this type of oil Motul 7100 20W50. I really wanted the Mobil V-Twin, but it is unavailable overhere in Italy. The auto part store overhere says it is formulated to Harley's specs.
Old Feb 25, 2009 | 08:10 AM
big cahuna's Avatar
big cahuna
I just took a look at the Amsoil white sheet page, and as far as comparing it to Motul they used motul 7100 in their tests. I don't know if thats the same stuff over where you are but, it held up pretty good compared to Amsoil. As long as it's the correct weight for the temperature where your at ,I would use it.,,,
Old Feb 25, 2009 | 08:21 AM
italfatboy's Avatar
italfatboy
Thanks for your input, I think I'll go for the Motul. They also have a Valvoline Durablend 20W50 for Motorcycles, but I think it's a synthetic blend.
Old Feb 25, 2009 | 09:12 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I would use the Valvoline after checking it because it meets the API CF designation and that is not shown on the Motul. Harley calls for the CF standard in the owners manual. Do not use it in the primary.
Motul: Meets API SL/SH/SG Jaso MA. For 4 stroke cycles with catalytic converters. Ester technology improves engine response. Low sulfer and phosphorus formula.
Valvoline: API SM/SL CF 20W-50
Old Feb 26, 2009 | 02:00 AM
italfatboy's Avatar
italfatboy
Thanks KBFXDLI!
You know I've always had good luck with Valvoline in the past, I think I'll stick with them. I don't let my oil go over 2,000 miles anyway.
Old Feb 26, 2009 | 10:47 AM
Gary7's Avatar
Gary7
Thanks KBFXDLI!
I was going to give you my opinion, but I think I already did over on BITOG.
Old Oct 6, 2019 | 02:23 PM
Petri Varpuharju's Avatar
Petri Varpuharju
CF is API designation for diesel engine oils
https://www.api.org/products-and-ser...s#tab-gasoline
so Motul should work just fine
HDF Tech
1868
Aug 11, 2023 03:02 PM
ludville1
15
Apr 2, 2017 10:02 AM
Bluegrasser
Jun 2, 2009 10:37 PM
fryeca
Jul 29, 2006 11:34 PM
shamboogiebanger
Apr 8, 2006 11:11 PM
