Oil Archive (no new posts) An archive of oil related questions and comments.
Miles Between Oil
Old Mar 24, 2009 | 03:22 PM
dynarule's Avatar
dynarule
Originally Posted by hd4evr2008
I just did an oil change on my 2007 SuperGlide with Mobil 1 V-Twin Syn..............can I just go back to HD 360 next change?
Yes you can and your engine will sound even better.
Old Mar 25, 2009 | 09:29 AM
Road Hawg's Avatar
Road Hawg
Originally Posted by big cahuna
Last Saturday I helped my friend do his 10k service on his RK. He insisted that being he's using Amsoil and paying a premium price for the ability to go 10k between oil changes he's gonna get his moneys worth from that oil.He changed the trans and primary as they were unknown brand . He rides alot mostly highway. Anyone else think that way?.,,
I use Amsoil as well I went 8500 mi and had the oil tested at Wheller oil labs. The results were amazing, the results were posted on this web site back in 08. As a result I change my oil around 8000 mi. I now have 40K on my bike with no issues and it hasn't burned any oil.
Old Mar 25, 2009 | 04:13 PM
dynarule's Avatar
dynarule
I feel sorry for the poor sap that gets your bike when you trade it in.
Old Mar 25, 2009 | 09:56 PM
Road Hawg's Avatar
Road Hawg
Dynarule, you sound like a guy that doesn't do his research before he opens his mouth,my oil was professionally tested it had no wear, no viscosity breakdown, nor did it have any metallic contamination. That tells me the oil was in great shape at 8500 miles.I could send you the test sheet but you probably wouldn't know what your looking at.
Old Mar 26, 2009 | 01:20 PM
WildBill2566's Avatar
WildBill2566
Sometimes its best to add some folks to your ignor list, saves a lot of unpleasantness.
Old Mar 26, 2009 | 05:54 PM
dynarule's Avatar
dynarule
Yea right!
Old Mar 26, 2009 | 10:05 PM
garyhendley's Avatar
garyhendley
i go 5000 on the motor and primary and 10000 on the tranny use synthetic on both
with no more metal shavings since i changed to synthetic a good synthetic anyways
ride safe
Old Mar 26, 2009 | 11:05 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
If you NEVER go more than 2,000-2,500 miles before changing what's the benefit of synthetic oil in a TC 96" engine other than running a little cooler?
Running cooler is the benefit. Friction/Heat is the enemy of all engines.
Old Mar 26, 2009 | 11:09 PM
KBFXDLI's Avatar
KBFXDLI
ride safe
If you use a good synthetic gear oil in the trans you can go 20,000 easily. I use Redline SHockproof Heavy and will run it 20-25,000 miles or 2-3 years. I inspect the condition of the oil for water intrusion but your trans can go a long time on syn oil since it doesn't create any combustion by products.
Old Apr 20, 2009 | 10:28 PM
oct1949's Avatar
oct1949
about 4500 on motor.
