Oil Archive (no new posts) An archive of oil related questions and comments.
Oil ?`s
Old May 2, 2006 | 12:56 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: Oil ?`s
ORIGINAL: NC_Biker
What I plan to do is alternate. 1st time drain & fill, next oilchange drain & scavenge and fill etc. thanks for the help. Now if I`m wrong correct me , on the engine oil - Mobil 20w/50, primary 20w/50 also, using the mobil1 VTwin 20w/50?......Tranny mobil 1 75-90 gear oil which I havnt been able to find yet.
Autozone should have all the Mobil1 products
Old May 2, 2006 | 01:00 PM
KBFXDLI's Avatar
KBFXDLI
Default RE: Oil ?`s
ORIGINAL: tripl8
"20w50 in his Vrod" ....brilliant..the VRod is water cooled...
Yeah......"brilliant" it has a shared sump....
Old May 2, 2006 | 01:10 PM
Willie D's Avatar
Willie D
Default RE: Oil ?`s
$58 seems like a lot, but well worth $$. I priced one out from both C-HD & Zanotti and the shipping co$t made it only a few $$$ difference, so it is a wash.
I made the the switch to Mobil 1 15w50 and still use the HD stuff (formula+) in the primary and the old Semi-Syn trans fluid (while you can still find it). When that is gone then I will prolly make the switch to Mobil 1 75-90 gear lube. I change it ALL evry 5k. Put 70k on a 2002 SERK w/o a problem that was oil related.
Buy the manual, you won't regret spending the $$.
JMHO
Old May 2, 2006 | 09:44 PM
tripl8's Avatar
tripl8
Default RE: Oil ?`s
Oh...i forgot..its Jap....
ORIGINAL: KBFXDLI
ORIGINAL: tripl8
Old May 2, 2006 | 09:49 PM
wlbowers's Avatar
wlbowers
Default RE: Oil ?`s
First oil change after buying a used Harley? Change everything, and sump it.
You might want to have an oil analysis done on the old oil. http://www.blackstone-labs.com/motorcycle.html Their standard analysis is only $20 bucks and they have tailored the test expecially for motorcycles. I ordered my test collection kit today.
I just went with Mobile V-Twin 20w-50 for my 2006 FXDLI. Dumped the Syn 3 out of both holes. The Transmission got Mobile Synthetic 75/90. Just too much damn noise with the syn3. And noise means wear.
I got my service manual on ebay. Cost me about $45, but Zanotti's has good prices as well.
Enjoy your ride.
Old May 2, 2006 | 10:34 PM
NC_Biker's Avatar
NC_Biker
Default RE: Oil ?`s
Got my manual today also . I`m putting Mobil one VTwin 20w\50 oil in the Oil Tank & primary. Here`s what I have read so far, remove oil plug from the Tank drain,let it drain out then remove the filter, clean everything & inspect , install the new filter and add 3 qts. run engine for 5 min or so & then check oil level for correct amount. I couldnt find 75\90 gear oil by mobil so I picked up some REVTECH 80\90. So far does everything sound OK to you guys as to the oils I`m using and the location of each? I havnt changed anything yet, studying a bit before I do anything. I Have a Manual WOOOHOOOO!!!!! Now if I could learn to read!!! LOL.. thxs gents,things would be Scary without your support.
Old May 3, 2006 | 12:45 AM
KBFXDLI's Avatar
KBFXDLI
Default RE: Oil ?`s
ORIGINAL: NC_Biker
If you go to Autozone and they don't have the Mobil1 75w90 just ask them and they will order it. But the Rev Tech should be fine as any gear oil will shear down less than motor oil in the trans. Now get yourself a torque wrench
Old May 3, 2006 | 01:45 AM
NC_Biker's Avatar
NC_Biker
Default RE: Oil ?`s
Funny you should say that, I have put off the lubricants changes until tomorrow until i get the torque wrench.. Like I said earlier I want to know its done right... thxs
Old May 3, 2006 | 01:47 AM
NC_Biker's Avatar
NC_Biker
Default RE: Oil ?`s
Another ?..What does FLSTCI stand for...
Old May 3, 2006 | 02:36 AM
KBFXDLI's Avatar
KBFXDLI
Default RE: Oil ?`s
ORIGINAL: NC_Biker
I believe that's the HD model designation for a Heritage Softail Classic Fuel Injected......my low rider is a FXDLI which is FXD= Dyna, FXDL= Dyna Low Rider Model, FXDLI= Dyna Low Rider Model Fuel Injected.......
