Oil Archive (no new posts) An archive of oil related questions and comments.
04 Electra glide standard help
Old Aug 13, 2009 | 08:36 AM
rteboe's Avatar
rteboe
Stage IV
Unhappy 04 Electra glide standard help
i have an 04 electra glide the oil light stayed on for me this morning oil lev is good where do i start to find out what it is
Old Aug 16, 2009 | 07:45 AM
Ugly Troll's Avatar
Ugly Troll
any responses? How many miles? Any unusual noises? What's your oil pressure like? Bike running ok? Could be just a short causing the light to stay on.....could be your cam chain tensioners took a **** and trashed your oil pump....
Old Aug 19, 2009 | 12:34 PM
rteboe's Avatar
rteboe
Stage IV
stock motor never wrenched on 36000 miles on bike problem was tensioner went out took out the oil pump going with hydraulic tensioners replacing pump, bearings and new cams high flow air and screamin eagle pipes
Old Aug 19, 2009 | 08:18 PM
Ugly Troll's Avatar
Ugly Troll
Cool, glad you got it figured out, sorry it's so pricey! If you haven't already moved on the tensioners, I'd strongly recommend going with gear drive cams. The hydraulic tensioners are better than the stock crap, but they will still wear and leave you at some point in the exact same situation. Going gear drive is more expensive, but only once. After the change you won't ever have to worry about the cam problems again! Always good to replace the bearings as well, and of course you already know you need a new pump. Keep us posted! Hope you're not down too long.
Old Apr 7, 2012 | 06:33 PM
montanabiker's Avatar
montanabiker
Stage I
Default 04 Electraglide
I have about 65K on my scoot now and am worried I might have trouble with an oil pump or other soon. Mine has a 95 kit with gear drives. Should I just go through the bike or replace it soon? Should I be nervous or just relax and ride it? She is running good for now.
Matt Glass
Nov 13, 2016 06:12 PM
markwolula
Engine Mechanical Topics
13
Sep 6, 2016 09:20 PM
KCelectraglide
May 22, 2014 08:00 PM
mrmud4x4
Jul 26, 2011 02:36 PM
0734
Exhaust System Topics
36
Jul 12, 2010 11:24 AM
