SYN 3 + cold temps
According to the "Material Safety Data Sheet" for H-D's SYN3, it is chemically a blend of 60% synthetic and 40% petroleum oils. But, the chemical composition notwithstanding, the courts have ruled that it is legal for them to advertise their "60/40 blend" as a "synthetic" motor oil.
Material Safety Data Sheet (MSDS) on the SYN-3, as filed with the Federal Government.
Manufactured by - Citgo Petroleum.
Composition section:
Component
CAS #
Concentration
(1) 1-Decene Homopolymer, hydrogenated
68037-01-4
50% - 70%
(2) Proprietary Ingredients
Proprietary Mixture
1% - 10%
(3) Polyisobutylene
9003-27-4
1% - 10%
(4) Distillates, Petroleum, Hydrotreated Heavy Paraffinic
64742-54-7
0% - 20%
(5) Distillates, Petroleum, Solvent-Refined Heavy Paraffinic
64741-88-4
0% - 20%
(6) Zinc Alkyldithiophosphate
68649-42-3
0% - 2%
Item (1) is a Group IV base oil. unable to locate the manufacturer of this base oil. Group IV and V base oils are the only "true" synthetics to the cognoscenti.
Item (2) is probably their additive package (boron, calcium, magnesium, phosphorous, moly), but it is conceivable there could also be some "secret" synthetic oil, maybe an ester type oil, included in it.
Item (3) is a fancy name for synthetic rubber (or elastomer) but this is probably considered to be "synthetic" oil as well.
However, Item (4) is a Group II base oil, namely Conoco Pure Performance Base Oil, either 110N, 225N or 600N. no one is calling a Group II oil a synthetic.
No information on the group number of Item (5), but it is Conoco's Cit-Con 650N Base Oil. It's presumed that it is a Group I oil as it is solvent refined. Most quality blenders are not using Group I oils in their premium motor oils and they are not considered synthetics.
(From the MSDS for the HD 360 20w50 oil: The major base oil constituents in it are the same ones as are listed in Items (4) & (5) above.)
I think the Items (4) & (5) above, are to keep the old air-heads running without bearing skid and gasket leaks. Good for them, but not for us?
Harley-Davidson talks about SYN3 in their advertising as:
"Developed with a proprietary blend of three synthetic base stocks, ..."
Or not ?
Since there are significant amounts of Group I and II oils in the SYN3, could the MoCo have stretched the definition of "synthetic" a bit further than Castrol did when changing Syntec from a PAO Group IV base to a hydro cracked Group III base?
Exxon/Mobil (Mobil 1 synthetic) lost a lawsuit trying to go after a few oil companies for advertising blends as full synthetic. Mobil lost, and now the oil companies do not have to disclose on the label it contains Group I, II or III base stocks which are all petroleum based.
So it is legal for Harley to market syn3 as a full synthetic, even though it is only 60% synthetic and the rest petroleum based.
Group I
Group I oils are the simplest, and usually will not be found in motorcycles.
Group II
Group II oils are refined by processes known as hydro cracking and isomerization. They have fewer impurities than Group I oils. These oils are the typical “dino” oils that are used in our bikes.
Group III
Group III oils are synthetic oils "so to speak". But they are not the type of synthetics that are built up from scratch but modified from dino base stock. They are actually crude oils from the ground that have been refined by a process known as hydroisomerization. HD Syn 3 falls into this category.
Basically it means a combination of processes that remove more unwanted impurities from the crude oil.
Notice above that group III oils are called "synthetic".
It took a lawsuit, and a firm of lawyers, and a bunch of law suits to decide that. The hydroisomerization process actually changes certain molecules around enough to create new molecules. These molecules are pretty uniform in size and shape, just like in “real” synthetic oil. These new molecules are more resistant to oxidation, so they’ll hold up better and last longer than before.
Group IV
Group IV oils are synthetic oils and are man made. These are one of the groups that most people think of when they talk about synthetic oil. The largest parts of these synthetic base stocks are known as “PAO”, for polyalphaolefin. This stuff starts with ethylene gas, a molecule with 2 carbon atoms, and builds up to a molecule with 10 carbon atoms. Then three of these 10 carbon molecules are combined to form the actual PAO. Each molecule is exactly like every other molecule. The molecules are long chains, are more stable, flow more readily, better resist heat induced breakdown, don’t thicken as much from high temperatures, better resist oxidation, and don’t “boil” off, than their dino oil base stock cousins.
Group V
Group V oils are ester-based synthetics. They made from diester, polyolestors, polyesters, and complex esters. They are extremely stable under high pressure, and resist heat, often to near 500ş F. They are polar molecules, containing an electrical charge that causes them to bond to metal surfaces. These oils are very expensive, and seldom encountered in our motorcycle world because of the price.
PS. I wouldn't use Amsoil either so we share that thought at least
What do you use in the trans and primary?
Your bike , you choose and if you choose the Syn 3, then you are paying synthetic oil prices for basically a dino oil, all other facts aside.
I wouldn't use it in anything when there are better oils available. Why do you think that many dealers will not put it in the transmissions any longer, only a few that find it easier to stock only one oil instead of different oils for different applications. Do some research and find out how many bearing failures and blued shifter forks from the heat generated from using Syn 3 in the transmissions.
It took a bunch of lawyers to get the classification changed to "synthetic" why do you think that is if it is really a synthetic?
"I think the Items (4) & (5) above, are to keep the old air-heads running without bearing skid and gasket leaks. Good for them, but not for us?"
Thanks
