Oil Archive (no new posts) An archive of oil related questions and comments.
SYN 3 + cold temps
Old Oct 11, 2010 | 09:50 AM
Jackie Paper's Avatar
Jackie Paper
Default 75-90,130>>
Originally Posted by big cahuna
I have run syn 3 in temps into the teens without an issue. It works fine. May not be the cheapest oil around, but it will do the job. Harley still to this day says to run it all three holes, just check their website. It has a gl1 rating which is all a light duty low horse power trans needs. Gear oil is the same wt as motor oils with less additives, so if you think 75/90 wt gear oil is some super thick honey that gives superior protection, your missing the point. You can run 10/40 wt oil in the winter if your due for a change, but if not keep the 20/50 in there you'll be fine.,,
Actual you are very correct since most of the 75->>> oils are GL5 rated meaning they have an anti friction additives added that Harley and the manufacturers of said brand oils say not to use in in the transmission. I ran it for a while a few months ago testing oils in my transmission and primary but after the test were done I took the GL5 out of the transmission. Never did the ATF oil test in the primary test due to warnings from the manufactors.
Old Oct 11, 2010 | 09:56 AM
Jackie Paper
Default It's not South
Originally Posted by dynarule
Funny how this always happens. Just ask a simple question and it goes south in a hurry.
It's not South. Just a little windy. Sorry did not mean to steal you space or get off tract. Thought you were getting your answer
Old Oct 11, 2010 | 01:35 PM
glideridemike's Avatar
glideridemike
Never said i was going to use it the trans! I wouldnt use any engine oil in the trans. Like I had said in my original post (if you read it) I asked a simple question about the cold pumpability of Syn3 over HD360 and dont give a rats a$% about other brands. The only difference between HD oils and all the high end brands is HD isnt getting on these forums and shoving there oil down everybody's throat and pulling out some ''White papers'' like a pistol.
WRONG on so many counts, but if you are stuck on using one brand, then so be it. Just don't defend your actions with bullsh!t like this.
Old Oct 11, 2010 | 02:26 PM
peppi's Avatar
peppi
Couldn't agree more with that Mike
Old Oct 11, 2010 | 02:54 PM
dynarule's Avatar
dynarule
Must have hit a nerve! Was it the "White papers" comment?
Old Oct 11, 2010 | 09:46 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
This is bullshit...please post these warnings. Please list the additives that should not be used in the transmission and why?
Old Oct 11, 2010 | 11:08 PM
Jackie Paper
Originally Posted by KBFXDLI
This is bull...please post these warnings. Please list the additives that should not be used in the transmission and why?
Just quoteing what I read. Everone needs to decide for themself and here both sides. I was testing Formual+ and Mobile's 75-90 Syn in my transmission for shift and noise. Could not tell any difference but after talking to Mobile took the 75-90 out. Have run in in 2 different 5 speed 4x4Toyota Transmissions since 83 and never hurt them. The 83 has 150K and the 89 has 200K and are still running. Also since we are talking Harleys in general here, there may be a differnece of the materials in a 4,5,or 6 speed and I have not worked on a Sporty but I think the fluids are seperate in it. Are the fluids seperate in a Sporty? Is there any yellow metals in a Harley transmission?
This was from the Mobile Site.
Question: Does Mobil 1 Synthetic Gear Lube Corrode Yellow Metals?Is Mobil 1 Synthetic Gear Lube LS 75W-90 gear oil OK to run in Harley Transmissions? The big buzz on the internet chat rooms is that it corrodes "yellow" metals, such as brass and copper. Is this true? Please answer THIS question.-- Michael Carravetta, Janesville, WI
Answer: Unless the transmission specifically recommends an API GL-5 fluid for your transmission, it should not be used. GL-5 gear oils are designed for gears that require a high level of EP (Extreme Pressure) additives to protect gear teeth under extreme stress. Unfortunately, these same additives can be very aggressive toward “yellow metals “and are generally not recommended where copper, brass and bronze components are used.
Question: ATF Choices for a Harley-Davidson FLHT PrimaryI have been told that many Harley owners use Type F (Ford) ATF in their primaries, for one thing to make it easier to find neutral. I have some Mobil 1 Synthetic ATF Multi-Vehicle Formula that I was thinking about putting in my FLHT primary, but the back label states that it's not recommended for Type F applications. I don't want to put it in my primary if it has a lot of friction modifiers in it because I don't want to cause clutch slippage. What are your thoughts on using this ATF in a Harley primary? Thanks.-- Ken Carpenter, Buford, GA
Answer: Although an ATF may work, we suggest shying away from using it due to the low viscosity of ATFs and the possibility of premature chain wear and/or noise.
Old Oct 11, 2010 | 11:15 PM
Jackie Paper
Default ???
Maybe its your white shirt
Old Oct 12, 2010 | 08:13 AM
glideridemike
LOL, you flatter yourself....lol, but that avatar sure hits a nerve!
I just don't want anyone who reads this to think that all these oils mentioned are comparable. There have been some long winded discussions over the differences in oils and there are many far superior oils compared to Syn3. Syn3 is not a pure synthetic, and pure synthetics are usually a better quality oil with many having a far higher 'flashpoint'. I have read several in depth studies concerning these different oils, all by impartial parties, not by any oil manufacturers.
Believe it or not, use what you want. Its no skin off my azz.
Old Oct 12, 2010 | 07:55 PM
OnTheFence's Avatar
OnTheFence
Gee no self flattery going on here. Thanks for you public service. Wouldn't it be awful if someone bought inferior oil.
