Oil Archive (no new posts) An archive of oil related questions and comments.
Mobil 1 - Primary
Old Oct 21, 2010 | 12:47 PM
Time2Cruise's Avatar
Time2Cruise
Default Mobil 1 - Primary
I've been using Mobil 1 in my engine and tranny, but to date have stuck with the Harley Formula + in the primary. I like Mobil1 because it s great synthetic and I get it wholesale from from my son-in-law, so I'd like to switch to M1 in the primary also. After hours of searching and reading this section, it seems there is no concenses on which Mobil1 works better in the primary. I don't mind the Formula + but it's more expensive than M1 for me.
Thoughts?
Old Oct 21, 2010 | 09:09 PM
Harleyboyddk's Avatar
Harleyboyddk
I'm using the Mobil 1 V-Twin in both my bikes motors, however stay with HD Formula+ in the primarys. Redline V-Twin transmission lube in the big twin transmission.
Old Oct 21, 2010 | 09:42 PM
peppi's Avatar
peppi
Agree with staying with the Formula+ in the primary. You don't want a synthetic oil in the primary, the clutch plates just need a regular oil that is not an energy conserving oil or synthetic.
Actually you can use any dino 10/30-10/40-20/50 oil in the primary with no problems as long as it isn't an energy conserving oil.
Old Apr 10, 2011 | 12:20 AM
Dissociative's Avatar
Dissociative
why not run syn 20/50 in primary?...mine seems fine?..
Old Apr 10, 2011 | 05:11 AM
ardakota's Avatar
ardakota
I have been running syn mobile 1 in my primary been working good for me
Old Apr 10, 2011 | 05:46 AM
Stiggy's Avatar
Stiggy
Sure it's fine, because it's overkill. None of the stresses that syn was designed to control in motors and trannys occur in the primary.
My 11 year old FLTRSEI just turned 86,000 miles last week. I run an M-6 chain tensioner and the cheapest 10W-40 dino in my primary that I can find.
Every component in there is original, includung the clutch plates.
( HD primary oil is just dino oil made by Sunoco. )
Old Apr 10, 2011 | 06:08 AM
y22c's Avatar
y22c
Thoughts?
If your cost on the Mobil 1 is less than you purchasing a conventional 20w50,
use it. If not , buy a conventional 20w50.
Ken
Old Apr 16, 2011 | 11:49 AM
46u's Avatar
46u
Mobile 1 works fine in the primary.
Old May 6, 2011 | 10:49 AM
UltraNutZ's Avatar
UltraNutZ
I'm having an issue now and I'll report back after the weekend. About a month ago, I switched from HD Syn3 oils to Redline in the transmission, mobil1 vtwin syn in the engine and mobil1 10w40 in the primary, all recommended.
My clutch is slipping with 16k on the bike now. I'm going to tear it down over the weekend and take a look-see at the clutch pack. Just find it ironic that it started after the mobil1 10w40 was put in there.
Old May 6, 2011 | 11:48 AM
troop's Avatar
troop
Good old basic Shell Rotella 15w-40 works well in the primary. Cheap too.........
