Oil Archive (no new posts) An archive of oil related questions and comments.
Leaking II
Old May 27, 2011 | 03:30 PM
rogran's Avatar
rogran
1st Gear
Default Leaking II
I recently purchased an 04 softail deuce, its my first Harley and I have not done my own maintenance on my bikes in the past. The bike had 5100 miles on it when I bought it and it had not had its 5k service. Being financially tapped after the purchase a coworker and fellow Harley owner said he would help and show me how to do everything, and save me a couple hundred bucks in the process. (The local dealer wanted almost $400 to do the 5k service.) He had never owned a softail and did not realize the oil drain plug was not where his was. We ended up pulling the two little plugs on the right side (bottom) front of the motor. After finding out that didn't get us anywhere we put them back tightened them up and eventually find the drain plug. Now a couple weeks and a couple hundred miles later I find that one or maybe both of those little plugs that we inadvertently pulled out is leaking. It doesn't seem to be major but I don't like leaks. They are tight and I don't want to over tighten. So my first question is what oil cavity are these plugs in, is it just crankcase oil? and What would you recommend to seal? I thought about Teflon tape or thread sealer? I do have a service manual ordered and on the way, just thought I would get a jump on it.
(I originally posted this in another area on this forum only to get harassed and called pathetic by some other user, lets see if this is a better location for a first timer)
Old May 27, 2011 | 07:36 PM
ardakota's Avatar
ardakota
clean them up and i would use some pipe sealer and put them back i dont think you will lose too much oil dont overtighten them cause they can crack your case and thats not good. And Dont take them out again.
jjpish
Dec 28, 2020 12:12 PM
writer1973
Jun 2, 2011 09:08 AM
raym
May 28, 2010 07:56 AM
rickeyhogrider
Jul 31, 2007 08:21 AM
Inferno00
May 4, 2006 06:16 PM
