Oil Archive (no new posts) An archive of oil related questions and comments.
Do not use Valvoline Racing Oil in Primary
Old Sep 8, 2012 | 11:51 AM
r0de_runr's Avatar
r0de_runr
Default Do not use Valvoline Racing Oil in Primary
2009 Ultra with 103 kit. Stock clutch spring. ~35,000 miles or so.
Last oil change I used Valvoline Full Synthetic Racing Oil 20/50 in the engine and primary. The blue stuff.
After about 2000 miles it started slipping under full throttle in 5th and 6th gear. Never noticed anything in the other gears. Thought I needed a clutch, took it to the shop and they just put in the extra-power spring and regular primary case lubricant. No problems now, $124 education.
Now I wish I had the stock spring back, but at least I'll never slip again.
Valvoline says do not use this oil in primary (now I researched it, did not before).
Old Sep 8, 2012 | 01:57 PM
roadglider05's Avatar
roadglider05
I had a similar problem with other synthetic oils in the primary, switched to Harley fomula + and problem went away. Called Valvoline and was informed the same thing, not to use the syn in the primary, too slippery. In the engine in performs great, have recently switched to Red Line oils and do not use in primary only engine and Transmission. Best so far.
Old Sep 8, 2012 | 04:41 PM
smitty901's Avatar
smitty901
Been running sny in primary for a long time never had any problems.
Maybe Valvoline has some strange additive in it.
bpd138
Jun 5, 2014 08:43 PM
blackflame
Jun 4, 2014 09:42 PM
robswglide
23
Feb 19, 2008 07:40 AM
dgb
23
Feb 26, 2006 05:04 AM
elcoyote58
Dec 14, 2005 12:22 AM
