Oil Archive (no new posts) An archive of oil related questions and comments.
tight oil filter
Old Nov 28, 2012 | 02:20 PM
aquadave's Avatar
aquadave
Default tight oil filter
Well I finally got my filter loose on my shovel head. It was so tight I bent 3 nice band filter wrenches. bought a lisiel with steel jaws bent it, popped a rubber strap wrench. Ended up using 2 wrenches at once, a steel band with a 3/8 ratchet along with a nylon strap wrench with a 1/2 ratchet. It was TIGHT. I know some of you would say drive a screwdriver through it. Well there's no room and I was afraid that it would just rip open like a can opener, it was that tight
Old Feb 20, 2013 | 10:26 AM
grbrown's Avatar
grbrown
My shovel had an internal filter, inside the oil tank, I take it yours has an external tin cartridge? My Evo has one, behind the trans, and the only way I have found that gets it off is indeed a large screw driver and big hammer! That hasn't failed me yet, in over 20 years.
Old Feb 20, 2013 | 11:33 AM
aquadave's Avatar
aquadave
mine's like yours behind the tranny. there is no way I could get a screw driver in there much less it was so tight I was afraid the if I did some how drive one in there it would just rip it apart. the 2 wrenches I used at the same time had extensions to bring them below the frame where I could put cheaters on both. It still collapsed the filter. I've worked on lots of engines in my life and never before had one that tight
cgsiluk
11
Mar 11, 2019 07:18 PM
skidder
Jan 31, 2014 01:25 AM
traildog
EVO
52
Aug 11, 2013 12:09 PM
BasketCase87
Mar 22, 2012 01:47 PM
jpnelson1978
Jul 24, 2006 06:28 PM
