Oil Archive (no new posts) An archive of oil related questions and comments.
Primary Oil Level Question
Old Feb 6, 2007 | 12:48 AM
FUN2XSs's Avatar
FUN2XSs
Default Primary Oil Level Question
I just finished up changing the oil in y primary. First time I have serviced myself. I have the manual. Bike is 2004 Ultra. Manual says not to over fill. It indicates 32 Oz. to is all to use. I added 32 Oz., but it still doesn't come close to bottom of opening cover. I have bike on lift not leaning on juffy stand, but the level is like 2-inches below opening of bottom of clutch inspection cover. Is this correct ?????????????
Yep I'm new, but ya gotta start somewhere
Old Feb 6, 2007 | 01:43 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: Primary Oil Level Question
ORIGINAL: FUN2XSs
That bike will take a quart - get and read a manual. It is not supposed to come to the bottom of the cover, just the bottom of the clutch spring when vertical - which is where you are describing.
Old Feb 6, 2007 | 02:17 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
If it says 32oz and you put 32oz in...you are done...close her up and forget about it.
Old Feb 6, 2007 | 11:36 PM
FUN2XSs's Avatar
FUN2XSs
Thanks all. I do have the manual and did read it says 32 oz is all to use the reason for my question was that there is a deceiving photo on the page that shows the oil leveland looks to be just below the opening. The photo in question is Fig 1-5 on page 1-17 of the 2004 Touring Manual. I just wanted to make sure. Never hurts to ask.
Thanks again all.
And OSEus new guysdo appreciate all you do for answering our sometimes lame questions.
Dennis
Old Feb 7, 2007 | 12:03 AM
Shovelhead Bob's Avatar
Shovelhead Bob
That picture shows the oil level to be at the bottom of the CLUTCH HUB SPRING (as OSE has already stated).... not the opening.....
FL (Touring) primaries generally take 38 to 44 oz of fluid (Normally the offset/remainder from the Trans Fill)....
More than likely you will need to add a few oz's to bring it up to spec.....
Old Feb 7, 2007 | 03:19 PM
mp's Avatar
mp
THE NUMBER OF OUNCES DOES NOT MATTER!
The only thing that matters is that the fluid covers the chain at the bottom of the clutch. It should be at a level that just touches the bottom of the clutch spring above the chain. The proper lubrication depends on the chain whipping through the fluid.
Old Feb 7, 2007 | 08:12 PM
KBFXDLI's Avatar
KBFXDLI
Not to change the subject but is the primary vented?
Old Feb 7, 2007 | 10:14 PM
sedbiker62's Avatar
sedbiker62
ORIGINAL: mp
I second this sentiment... You will likely need to add like shovelhead bob said. I have about 36-38 ounces in my 06 ultra.
Steve[sm=icon_rock.gif]
Old Feb 8, 2007 | 11:36 PM
FUN2XSs's Avatar
FUN2XSs
Thanks all. It looks to be at or level with the flange at what I assume you are describing as maybe the clutch hub. It looks like about another 2oz more would put it at about 1/4 over the flange on the clutch hub, which is about where the photo shows upon closer review.
Thanks Shovelhead
Old Feb 8, 2007 | 11:38 PM
FUN2XSs's Avatar
FUN2XSs
Next up the trans service lube change
