Oil Archive (no new posts) An archive of oil related questions and comments.
1990 FXR Lowrider Oil Light On
Old Apr 22, 2014 | 06:16 PM
9192daveyc's Avatar
9192daveyc
3rd Gear
Default 1990 FXR Lowrider Oil Light On
I ride a 1990 FXR Lowrider. Monday the oil light came on indicating low oil pressure. I immediately changed the oil and started the bike and let it run. After a minute the oil light began to flicker on and off but didn't fully come on. My biggest fear is the oil pump is out. Any suggestions or tips as to what it may be is appreciated. Thanks guys.
Old Apr 22, 2014 | 07:44 PM
Greezey Rider's Avatar
Greezey Rider
It is likely that you have a key sheared off in the pump, if you do, it'll need to be rebuilt.
Rebuilding or replacing those old oil pumps is pretty simple.
If the oil pump body is scored, it'll have to be replaced.
Old Apr 23, 2014 | 06:39 AM
big cahuna's Avatar
big cahuna
First, I wouldn't continue to ride it until you figured out what's goin on. I would pull and check the screen on the pump to be sure it's not blocked with something. Check that the pressure switch is working. You can also add a manual gauge,so you can see how much pressure you have. It could be a loose wire somewhere, giving you an intermittent signal.,,
Old Apr 23, 2014 | 10:00 AM
JustDave13's Avatar
JustDave13
Remove the sending unit and hook up an oil pressure gauge to it and take readings, you could just have a faulty sending unit.
Old Apr 25, 2014 | 07:22 AM
grbrown's Avatar
grbrown
I was taught that when a warning light comes on, the only thing we can be sure of is that the bulb works! So I agree with Dave, start by checking the pressure sensing stuff, before you go any further. A switch turned the bulb on - so check the switch as it may be faulty!
9192daveyc
Engine Mechanical Topics
Apr 22, 2014 02:52 PM
Harbri
Shovelhead
Nov 13, 2011 09:34 PM
clank66
Exhaust System Topics
Jun 4, 2011 05:44 PM
poppop
Shovelhead
May 23, 2009 03:18 PM
RoadkingFD
Jun 17, 2007 12:36 AM
