Pan America Pan America Forum Only
Some issues
Old Aug 30, 2021 | 10:38 AM
  #31
fwg1961's Avatar
fwg1961
Originally Posted by deadeye
I saw that video about wrapping the pipe with heat tape but can anyone confirm it makes much of a difference? I thought a better heat shield that was covering more of the pipe might be a solution but probably nothing short of a cat delete is going to cure the heat.
Wrapping an exhaust pipe is really not a good idea as it causes problems with the pipe in the long run, as it weakens the metal in the pipe.
Old Aug 30, 2021 | 11:13 AM
  #32
PANTED's Avatar
PANTED
Yesterday to try and at least improve the problem I tried using spacers with longer screws to get the shield away from the pipe but because of the position of the lugs on the pipe it did nothing. I think Harley should have spaced this shield further out and placed vents in it.
Old Aug 30, 2021 | 11:17 AM
  #33
adm's Avatar
adm
Originally Posted by PANTED
Thank you for responding to my thread. It's great information & at Ł20 not as expensive as I thought it would be given the word Harley seems to increase the price of everything. Given it won't need the valves adjusting g first service cost will be interesting. Returning to coolant issue I have just been out to check the level again on the dip stick & it's now zero.Which is worrying. There's no coolant under the bike which is good but I am now wondering whether to ride it to the dealers tomorrow or get them to collect it.I don't even want to start the engine to check whether the warning light is on. I am just intrigued as to why this is happening. Makes me think I am back in 1903 when they were having issues then 😉
Bear in mind that the dipstick is not actually checking the coolant level. It is checking the level of coolant in the expansion tank. So it's not like there is no coolant in the bike - just none in the expansion tank.
Personally, I would just ride it to the dealership and have them check it. But that does create the issue that the bike will be hot when you get there and it will need to cool down before they can check it accurately. So you may need to hang around for a while....
Old Aug 30, 2021 | 11:21 AM
  #34
BigMike's Avatar
BigMike
Glad you guys are paying to beta test these bikes for HD.
Old Aug 30, 2021 | 12:04 PM
  #35
PANTED's Avatar
PANTED
Thank you great advice again. I will do that as I get free coffee anyway. Can I ask given its only a small amount of coolant needs topping up would it run that much hotter.
Old Aug 30, 2021 | 12:08 PM
  #36
PANTED's Avatar
PANTED
Ha ! Ha ! Cheeky Mike 🤣 but you make a fair point. Only excuse I have for buying it is I need to buy one now as aged 70 tomorrow might be too late. Just thank us when you do buy one as clearly you will 😉
Old Aug 30, 2021 | 12:16 PM
  #37
TN-Squirrel's Avatar
TN-Squirrel
Hell, as a network engineer I wish computers and software where this great at Beta! Best birthday gift - 60 - I ever gave to myself.
Old Aug 30, 2021 | 12:26 PM
  #38
adm's Avatar
adm
Honestly, I wouldn't have thought so. What temp was the engine showing when you were riding the bike? I have seen mine up to 220F so far.
It does get hot - and got really hot yesterday when I was stuck in traffic for 15 minutes, but no hotter than my air cooled Harleys have done.
I certainly wouldn't wear shorts and flip flops on this bike. But I normally wear bike boots and armoured bike jeans.
Your stats show you are in Eastbourne, so presumably your supplying dealer is Sykes on the A22? It's only about 12 miles so I wouldn't worry about it.
Bottom line is it's up to the dealer to sort it for you. The bike is in warranty and they should have done a pre-delivery inspection and made sure the coolant tank was topped up to spec. Mine also didn't - but I already had the jug of coolant at home when the bike was delivered.
Old Aug 30, 2021 | 01:24 PM
  #39
PANTED's Avatar
PANTED
😉 Who said age is just a number 🤔
Old Aug 30, 2021 | 08:34 PM
  #40
fwg1961's Avatar
fwg1961
I put some of the gold reflective heat tape on the inside of the heat shield today, I'm curious to see if it helps any. I have used it on cables and wiring that ran to close to headers and such in the past and it worked well. I will let you know how it works out.
