Pan America Pan America Forum Only
Anyone changed their battery ?
Old Apr 28, 2022 | 03:52 AM
David V #44's Avatar
David V #44
Default Anyone changed their battery ?
Anyone changed their battery yet ? Either for a new HD one or a different replacement. Maybe a stronger battery.
I say this because even though I put my PA on a tender most of the time, last week after leaving it only 3 days unplugged it was flat.
I've seen what seem to be better performance batteries on line here. What do you think ?
• HD original 12Ah with CCA (cold cranking amps) 200A (sealed lead/acid I think)
• Gel performance 14Ah with CCA 250A
Can I just swap ? Do I have to pull out the main fuse before ?
Old Apr 28, 2022 | 04:18 AM
Prykey's Avatar
Prykey
I can't comment on compatibility, I'm pretty sure that you will need to disarm the alarm so pulling the main fuse wouldn't be a bad idea, perhaps one of the Tech's on here will be able to comment from a position of experience.
Old Apr 28, 2022 | 08:28 AM
CrewDawg_CO's Avatar
CrewDawg_CO
I'm thinking about installing this battery.
https://www.impactbattery.com/mhtx16...m-battery.html
1. Models with security: Disable security system.
a. Verify that fob is present.
b. Turn OFF/RUN switch to RUN.
2. Remove right steering head cover.
3. See Electrical → POWER DISCONNECT → Main Fuse → Main Fuse. Remove main fuse.
4. Models with security: Turn OFF/RUN switch to OFF.
After battery install, install main fuse and right steering head cover.
Old Apr 28, 2022 | 02:22 PM
mskirwin's Avatar
mskirwin
I changed the battery on my ‘15 LTD with fob on bike without pulling the main fuse with no issues.
Old Apr 28, 2022 | 03:55 PM
Prykey's Avatar
Prykey
That looks like an interesting battery technology, not seen anything like that being advertised in the UK yet to my knowledge.
Old Apr 28, 2022 | 09:28 PM
NODYNA's Avatar
NODYNA
I think one of the latest software updates corrected the battery drain issue. Before buying another battery that will also drain be sure you have the latest software update. It's a free service form HD.
SeniorChief56
Oct 20, 2019 01:32 PM
My2Harleys
Electrical/Lighting/Alarm
13
Jul 17, 2014 06:49 PM
Dilligaffer
General Topics/Tech Tips
Mar 27, 2013 01:21 PM
shredsurf
Nov 20, 2011 10:14 AM
StreetGlider57
Oct 19, 2010 07:41 AM
