Pan America Pan America Forum Only
*SOLVED* ARH PanAm
Old Oct 11, 2022 | 10:10 PM
  #31
tri cycle's Avatar
tri cycle
I appreciate the heads up from the OP. My bike would lower when started but not when coming to a stop, despite the flashing icon indicating the bike was lowered. No warning lights of any kind...all appeared "normal". Checked the schematic against my bike and pins 5 and 6 were switched as well as 7 and 8. Dealership corrected the issue, recalibrated the ARH, and all is well.
Anybody seen HD Quality lately?
Old Oct 27, 2022 | 04:56 AM
  #32
22pasrider's Avatar
22pasrider
Stage I
Default Mine does the same thing!
Originally Posted by Red.Road.Glide;[url=tel:20818981
20818981[/url]]Interesting, I'll have to look at my wire harness. My ARH every once in awhile will disengage while riding and I've come to realize it has disengaged because the yellow triangle turns on. When I stop, it will remain in the up position, which is significantly higher (to me) than when the ARH is engaged. So far it has reset itself every time I've turned the bike off, let is set for a few mins and then restart; at which time the ARH will work correctly until whenever it wants to disengage again. It is so intermittent, it is very hard to show it to the dealer when I take it in, but it does happen. They do not seem to ride our bikes long enough during service for intermittent events to occur, so the default answer is update the BCM, ECM and software, and say it's working correctly.
For about the first 1800 miles or so I was also getting an intermittent stall when decelerating. Like the ARH it would happen every now and then I could not seem to replicate the problem. But, I am at about 3300 miles now and it has not happened in awhile, as if it worked itself out.
Mine does the same thing. When I spoke with the dealer, they thought I was nuts. They want to charge me $75 for a software update. I’m going to try that myself, although I don’t think it will help. I’ve found that if I leave it in road mode, all is well. As soon as I change riding modes, it acts up. The orange triangle comes on and the suspension won’t lower.
Old Oct 27, 2022 | 10:30 AM
  #33
ChocolateCake's Avatar
ChocolateCake
At the 6K-miles had the software update for a ***** ARH but now at 6600-miles I now again occasionally get my bike not lowering.
Also weird after the software update I lost the ability to get charging form my USB - on right side of display, and eve weirder my QuickShift stopped working.
I guess at the 10K mile service I'll have it looked at.
Old Oct 27, 2022 | 10:50 AM
  #34
ornrry1's Avatar
ornrry1
Sounds like they actually went backwards with the software instead of updating.
Old Apr 20, 2023 | 10:49 AM
  #35
CVORoadKing2013's Avatar
CVORoadKing2013
Did fixing the wire actually fix suspension issues for people? I have a Pan America Special Non ARH. I do not get errors, but I do feel like the suspension locks high and is to stiff at times.
My connector is wired wrong:
Pin 1 2 3 4 5 6 7 8
White Black Black White Black White Black White
I plan on correcting it to match the wiring diagram just curious if it fixes anything
Old Apr 22, 2023 | 07:42 AM
  #36
doxbike's Avatar
doxbike
Software updates should be free
Old Apr 22, 2023 | 10:54 AM
  #37
ornrry1's Avatar
ornrry1
Ok I'll bite, if you have the Non ARH, why do you think you have an issue? If it doesn't have ARH, it doesn't auto lower.
Old May 6, 2023 | 01:42 PM
  #38
BlueSkyRider's Avatar
BlueSkyRider
Stage I
So I checked my wires on a ‘22 with ARH. Positions 3, 4 and 5-8 are all wrong. Additionally, does anyone have a part number for the female connector?
Old May 8, 2023 | 08:34 AM
  #39
3dognate's Avatar
3dognate
No part# but you should be able to pickup a de-pinning tool from Amazon and use that to swap the wires around to the correct spot. No-need to destroy the stock connector unless it's already boogered.
Old May 22, 2023 | 03:06 PM
  #40
mountaintime's Avatar
mountaintime
