Rebuilding star hub.
Old Jan 11, 2022 | 09:10 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted sorry
Old Jan 11, 2022 | 11:32 AM
OLD 96's Avatar
OLD 96
Wowsa that's small. What is deviation factor of new bearings?
.001"- .0015". Oversize available in .0002" increments. I found a place that has .002" oversize.
Originally Posted by hellonewman
Same bearings used on the crank I believe. You could go down to .008" I imagine, its not like its a high speed application when you think about how slowly the hub rotates at speed.
I think you mean.0008". I might could go .0008". But. That would put it under spec. Especially when it heats up. I'm going with the .0006" OS bearings. Thanks. All advice is taken under consideration and appreciated.
Old Jan 11, 2022 | 03:53 PM
hellonewman's Avatar
hellonewman
Yes typo but I still figured 8 tenths wouldn't be cause for Defcon-4, my bad!
Old Jan 18, 2022 | 09:59 PM
OLD 96's Avatar
OLD 96
Got my stuff in today. Going try and put wheels together tomorrow.
Old Jan 20, 2022 | 05:53 PM
OLD 96's Avatar
OLD 96
Got both wheels done last night before the cold front hit. 30 degrees is the high here today. Every thing assembled End play set. Now just wait for it to warm up a little take every thing apart grease things up. Final assembly and put it all back together.
Thegen58
Jun 30, 2020 11:27 AM
rwven
2014-2024 Touring Models
15
Jun 25, 2018 08:51 PM
PTS
Jun 4, 2017 02:43 PM
Mikey_P
Wheels/Tires
Jun 16, 2016 07:06 PM
Vuoso86
Mar 27, 2015 05:20 PM
