Speedometer woes
Old Nov 12, 2023 | 09:40 AM
  #41
NM Pan-shovel's Avatar
NM Pan-shovel
Eastwood also said "I never shot anyone who didn't deserve to die."
Seriously, though, I replaced the guts on my '67 MG Midget speedo with the innards from a '74, but that didn't involve disassembling the drive unit--which I tried unsuccessfully with the '67 (messed up the clock spring). Basically, it looks like dealing with the odometer drums is pretty idiot proof. In my experience playing with the Midget speedo, it's the clock spring and magnet drive that are more delicate. Then there's having enough spare parts lying around if [x] component is not serviceable.
All things considered, around $300 (his current rebuild rate) give or take is probably worth freeing me up to continue the kitchen rebuild so the wife doesn't move out.
Well, let's see whether I'm overwhelmed by an urge to take the darned thing apart when it gets here, or if I'm able to control myself... I'm eager to see it in the flesh. It'll be a neat finishing touch to this build, for sure.
Old Nov 12, 2023 | 11:07 AM
  #42
NM Pan-shovel
This is a very cool thread from some Jeep guys, showing some techniques and also describing materials and parts, including something called Restom Aludecap D.D.M. 2050 to clean up the cast frame.
Here is an exploded view of the Stewart Warner speedo from the Jeep this guy is restoring. Its guts look roughly similar to the Harley SW gauge... with a few obvious differences...
Old Nov 12, 2023 | 11:28 AM
  #43
NM Pan-shovel
Again, I'm sure there are numerous differences due to configuration on the Harleys, but these guys include really helpful stuff...
"One side of the trip and odometer is retained by a flat spring.
Use a flat screw driver to release the spring and remove the odometer.
The trip meter is a bit more tricky because you need :
1 - release the flat spring
2- pull the trip meter out on the flat spring side
3- push the other side towards the inside.
4- remove the reset lever
5- remove the external gear
6- remove the trip meter."
Old Nov 12, 2023 | 11:42 AM
  #44
FL54's Avatar
FL54
Keeping the wife happy or possibly saving $300. Hmmmm let me think about this for a moment. If she does move out (just kidding) , it will cost you a damn sight more than $300.
Old Nov 12, 2023 | 11:48 AM
  #45
FL54's Avatar
FL54
Originally Posted by johnjzjz
He does all the stuff from the shop and never had one come back with an issue / you never will see a u haul behind your hearse - you can't bring it with you
Wait a minute John. Someone forgot to tell this guy you couldn’t take it with him.
Old Nov 12, 2023 | 11:52 AM
  #46
NM Pan-shovel
You guys are hilarious... I'm gonna bust a gut if you don't cut it out!
BTW - Please tell me that is photoshopped and not a real image...
Old Nov 12, 2023 | 12:53 PM
  #47
NM Pan-shovel
This is a simple, cheap, ingenious tool for removing the needle--kind of like a miniature pulley remover...
The wood arrangement on which the tool rests is a die for crimping the new (or refurbished old) bezel back on. He used the wrong method for cutting the big hole and chipped the wood (I make cabinets as a hobby). The far better method is to cut a hoop for your router, then plunge your spiral bit and just orbit the router... voila. Perfect, clean hole with a flat bottom to receive the bezel.
But if I were to do a series of speedos, I'd just walk next door to my machine shop and have a die CNC machined out of 6061-T6... oh, yeah, that kitchen thing again...
Old Nov 12, 2023 | 02:12 PM
  #48
FL54's Avatar
FL54
Much better than prying it off with a couple of flat screwdrivers.
Old Nov 13, 2023 | 08:32 PM
  #49
OLD 96's Avatar
OLD 96
May I be allowed to insert this? I have used Scott's Speedometer Service is in the past. Very good experience. Do not mean to rain on the parade. Always good to shop around. Thanks. Ride safe.
https://scottspeedometer.com/
Old Nov 13, 2023 | 08:53 PM
  #50
NM Pan-shovel
Oh, cool, thanks very much. Yes, definitely good to have options!
