61 panhead winter storage
Old Nov 5, 2025 | 04:05 PM
oldharleyrider2's Avatar
oldharleyrider2
Default 61 panhead winter storage
new 61 panhead owner. i've never owned anything older than a 68 flh. i am now the proud owner of a 61 panhead. Pans rule. anyway i'm getting ready to put it up for winter storage. should i drain the oil or leave it in the oil tank? my thought that the oil may leak past the check ball and fill the crankcase over the winter months open to any suggestions..
Old Nov 5, 2025 | 07:32 PM
hellonewman's Avatar
hellonewman
My 61 sumps. If you change your oil once a season then its half done if you drain it now. You can shoot oil the cylinders if it makes you feel good but when I bought mine from a long term owner, it sat in his basement for 23 years without any attention and it didn't take much for me to get it running again.
Old Nov 6, 2025 | 07:33 AM
Architect's Avatar
Architect
I would leave the oil in the bike. I would add a fuel stabilizer and run the carb dry and that is about it. Knowing that she might sump is half the battle come Spring, then you know to put a pan under your Pan in case she pukes. Good luck.
Old Nov 6, 2025 | 07:55 AM
FL54's Avatar
FL54
I don’t treat my Panhead any differently than the Shovels. I just fill the tanks, add fuel stabilizer, put them on a battery tender and forget them ‘till Spring.
Old Nov 12, 2025 | 05:46 AM
Ron Pinette's Avatar
Ron Pinette
They all sump, some worse than others. If mine was a sumper I would dump the oil and fill new in the spring. It will start easier and be less messy.
LQQK_OUT
Jan 28, 2025 03:31 PM
mxdeanmay
Oil Archive (no new posts)
Aug 22, 2023 01:19 PM
svshaw82
Panhead
17
Aug 14, 2018 04:27 PM
kickstart pan
Classic Harley Parts
Jan 3, 2012 02:57 PM
woollyb
Panhead
17
Nov 22, 2010 05:34 PM
