'54 panhead oil cover replacement
Old Feb 10, 2026 | 07:41 AM
captankirktng's Avatar
captankirktng
Default '54 panhead oil cover replacement
Trying to install a remote filter, and when I put the fitting for the oil return line from the pump to the filter the threads in the cover (1/8" NPT female I believe) felt stripped. It seems to be tight but not taking a chance. Got enough oil problems as it is.
So, I'm replacing the oil pump cover. Anything of any issue I need to know? It looks and sounds simple (I've read a couple scenarios).
Any info from those experienced would be appreciated.
Old Feb 12, 2026 | 11:17 AM
panz4ever's Avatar
panz4ever
Straight forward as you say.
1 Use a new gasket
2. Remember torque sequence on nuts is measured in inch pounds.
3. After reconnecting lines, just make sure your have oil returning to the tank after start up. Sometimes air gets in the lines.
razorbacksrule
2018+ Softail Models
56
Jul 12, 2025 10:45 AM
CaffeineBuzz
General Topics/Tech Tips
Apr 23, 2021 07:02 AM
mikeo33y
Jun 8, 2014 08:47 PM
khui
May 13, 2013 06:34 AM
SFTail06
Oil Archive (no new posts)
Nov 5, 2007 09:02 AM
