Front terminal board - Springer PH
Old Sep 19, 2007 | 12:37 PM
MontanaPanFan's Avatar
MontanaPanFan
6th Gear
Default Front terminal board - Springer PH
Hello all,
New to the forum, thanks in advance for any help.
I have a project, a 48 frame, a 48 front, a 61 motor, I am making an open front bobber, and i have a new replica wiring group. All diagrams make sense, except ---
The wiring diagram shows a front terminal block, located behind the horn I think. I am not using the horn in the front, (I will locate elsewhere), only headlight, dimmer, and horn button. I have the replica springer bars with internal cloth wiring, four wires.
The diagram of where to connect all the wires makes sense, except, on the front of the terminal block diagram, one terminal is red, and connects to the terminal block, and does not continue ( no other wire connects to it , on the front anyway, I am sure it connects to something on the back of the fiberboard terminal), the other mystery terminal is yellow, which also does not have a linking wire on the front of the board, but must connect to something on the back,??
As I do not have the terminal board to look at, I do not know what occurs on the back of the board, maybe linked with solder, plates, or wire or something.
I am going to make my own, smaller terminal board, but any help on where the two, or more unknown terminals go to. I think they should not just connect to the front of the board, and terminate, this does not make much sense???? But, I could be totally off on this.
Any and all help, appreciated.
MontanaPanFan
Old Sep 19, 2007 | 04:49 PM
pittguy's Avatar
pittguy
Default RE: Front terminal board - Springer PH
The yellow wire goes from tank switch terminal #3 to terminal board postion 20 and is used only with parking lamps.
Old Sep 19, 2007 | 04:50 PM
pittguy's Avatar
pittguy
All connections are one sided on board.
13RoadKing
Electrical/Lighting/Alarm
Feb 28, 2017 07:17 PM
Bigwingboy
Dec 11, 2014 09:45 PM
rockon
Feb 21, 2014 01:33 PM
Afishionado
Nov 21, 2012 09:00 PM
m i k e
Jun 5, 2009 11:53 AM
