Super E on a pan?
Old Feb 15, 2008 | 01:26 AM
Da Gumpmeister's Avatar
Da Gumpmeister
Default RE: Super E on a pan?
Old "B" is the new "E"
Old "D" is the new "G"
Use the "E", as the "G" will drown it. "G" is great if you're running over 86" and developing HP and R's
Other than that, update the manifold, and you're good to go. Amer. Iron Mag, Feb 08 issue has a SOOOPER article on tuning the "E" and "G" carbs. Follow that, and you will be more than "in the ballpark" Happy "panning" and enjoy your "tinker"toy.
Old Feb 29, 2008 | 11:49 AM
meatz's Avatar
meatz
go with the E for shure and id go with a 72 or 74 main jet and a 29 inter. jet to get you started and get rid of the points and put a mallory unilite distributor in it
Old May 12, 2008 | 12:10 PM
keiser's Avatar
keiser
Stage I
ORIGINAL: sqdealgeorge
My 52 has a B S&S 22years now Its great
By any chance do you run with the original wire throttle cable or did you convert to later style? I am trying to use the original but it won't quite open my "B" throttle all the way. It should have enough movement to do it, but the wire seems to only move about 70% of the total movement at the handlebars.
Old Jun 4, 2008 | 03:44 AM
SloRoll's Avatar
SloRoll
6th Gear
I run a Super E on my 49 Pan and it works just fine. Running .71 main and .295 intermediate. I also installed a Sifton Bomb Site to get better atomization of the fuel. A good friend of mine (whoI highly trust in these matters)swears the B model it the cats meow for Panheads.
Old Jun 8, 2008 | 10:39 PM
badinfluence63's Avatar
badinfluence63
I ran my 1963 pan/rigid without trouble forever on a zenith bendix. I preferred that because although the Super E has the accelerator pump the bendix had what I thought to be a&nbsp\\;good old fashioned choke. It created the sequence needed to start the bike. I imagine though the super e accelerator pump can be to an advantage on a kick only? I didn't change mine, no reason to.
&nbsp\\;
I&nbsp\\;do run a super e on my 1983 and its a great carb.
Old Aug 5, 2022 | 05:57 PM
Sergio Saenz's Avatar
Sergio Saenz
Stage I
Originally Posted by Bigg
I recently changed my 50 Panhead from a S&S B to a Super E... Its great, Best Thing you can do.. You will have to convert to o ring manifold (mine was already converted) but you will also have to use a extension block and the taller cable brackets to get it to work which is minor. The end results is a motor that starts easier. (I am down to two pre kicks one to start, no throttle when cold, one to start warm).You will also have better throttle response, better idle, smoother running all around. Good Luck !
what size bolt did you have to upgrade to when you used the spacer?
I'm currently trying to convert my bendix single cable carb to a super e and am having a tough time piecing it together.
Old Aug 5, 2022 | 06:24 PM
hellonewman's Avatar
hellonewman
Dont hold your breath, he hasn't logged in since 2008
Old Aug 5, 2022 | 06:26 PM
TwiZted Biker's Avatar
TwiZted Biker
14 year old thread my friend, start you own and ask, lots of good folks in here to help you.
Old Aug 8, 2022 | 08:10 AM
Docmel's Avatar
Docmel
SS Es have been on pans for a long time now. They are very easy to set up, and SS has a very good site tha has great tech videos. Anytime you hear someone complain about thier SS E is because its operator error: Many so called issues come from NOT READING THE BASIC INSTALLATION MANUAL
Frankly, anyone that recommends jet sizes for your bike, based on thier engine, is just plain wrong. Quality of tune, engine condition, elevation and "self interpreting" the instruction manual makes all bikes different. USE THE RECOMMENDED JET SIZES that SS recommends and go from there in your tune. They have spent thousands of man hours and $$$ in research
SS Es are basically bolt on and go. Adjust idle and accel pump (Again, read the MANUAL) and typically, you are good to go. Chasing down jets w/o first using the factory recommended sizes will turn into a tuning nightmare
Most self induced issues I have found from others are a misadjusted accel pump, or poor tuning or engine condition
I can emphasize enough: Use the manual and read it closely. Its simple and easy to install and get it running
jdbluedevils39
Exhaust System Topics
Mar 18, 2010 05:14 PM
jdbluedevils39
Oct 25, 2009 05:36 AM
StreetGlideMedic
Gear and Other Items For Sale
Oct 7, 2009 05:55 PM
henryr
Apr 3, 2009 07:30 AM
