Panhead heads - tightening
Old Oct 8, 2007 | 12:45 PM
MontanaPanFan's Avatar
MontanaPanFan
6th Gear
Default Panhead heads - tightening
Hello.
I am close to finishing a total rebuild of a 48/61 panhead project.
The motor is in place, the heads are on and I am about to tighten them down to the cylinders.
I think I read torque to 80 lbs, but as you guys know, the heads of the bolts are hard to get to, and really hard to torque,
I do not have the special wrenches, which are not torque wrenches anyway.
So, How do I get these tight, and what are the best wrenches- sockets to use to tighten with, Do I need the special harley wrenches?
I am running a magneto, so one of the front bolts is a real bitch, I will take off the magneto at the base, and have more room to work around that.
These things look like a bitch to tighten, and a nightmare ot actually torque. 80-85 lbs is correct?
Any ideas!!!
Thanks
Old Oct 8, 2007 | 01:35 PM
pittguy's Avatar
pittguy
Default RE: Panhead heads - tightening
Some owners have made special tools for the way their bikes are.A torque adapter may be needed but remember extending the length willthrow tq specs off,torqing at 90 degrees-tq wrench to adapter-should be used to remain w/in specs.Remember that tq should be checked agin after heat cycling engine.
Old Oct 11, 2007 | 02:06 PM
crampfan's Avatar
crampfan
Head bolt torq. is 65 ft.lbs. I use a 9/16 wobble socket, you can get to all the bolts but the one near the point breaker assm. and I use a dog bone for that one, (you will have to do some math to get your torq wrench set w/ a dog bone)
always retorq. after about 500 miles. (unless you like doing headgaskets)
Old Oct 13, 2007 | 04:07 PM
wreck74's Avatar
wreck74
This workswith James gaskets. you can feel how tight to tighten it, and pretty even too.
Old Oct 13, 2007 | 07:34 PM
Hal64hd's Avatar
Hal64hd
The Special Tool I Use is a GM Door Hinge Wrench
http://cgi.ebay.com/ebaymotors/Snap-...spagenameZWDVW
[IMG]local://upfiles/24357/F46F70C8CFDD48678BDED66B9AD04C38.jpg[/IMG]
Old Oct 21, 2007 | 10:48 AM
MontanaPanFan
6th Gear
Thanks for all the help.
Where can i buy a set of three of the U shaped wrenches for harleys?
jsbridgew
Engine Mechanical Topics
13
Jun 27, 2015 07:06 PM
krwilson830
Shovelhead
Aug 12, 2011 07:38 PM
sdbull65
Shovelhead
Aug 16, 2007 05:17 PM
Hoze
Flathead
Apr 11, 2007 02:19 PM
ragman
Shovelhead
Nov 27, 2006 11:30 PM
